Old 07-27-2011, 06:27 AM
Liquid Ghost Liquid Ghost is offline
Default HD Core PCI/accel PCIe
Is there a processing difference in the PCI core vrs. the accel PCIe core card?
Since the Accel process card has twice the processing as a regular process card is it the same way in the core cards?
Old 07-27-2011, 08:43 AM
Raoul23 Raoul23 is offline
Default Re: HD Core PCI/accel PCIe
Apparently a HD3 accel pci and HD3 Accel pcie are apparantly the same when i lasst looked at the white papers
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 07-27-2011, 01:27 PM
I understand that but i want to know if the New Accwl PCIe core card is more powerfull than the origional standard HD PCI core card.
Old 07-28-2011, 09:15 AM
What I read when I was researching into purchasing my PTHD system it said that a hd 1 accel system was alot more powerful than just a hd 1 system but as u add extra accel cards the difference becomes minimal
Raoul Crane
Old 07-29-2011, 09:25 AM
themidiroom themidiroom is offline
I don't see why the Accel core wouldn't provide more proccessing power than a HD core.
The MIDI Room Transforming your concepts into reality
Old 08-03-2011, 03:06 AM
lennieh lennieh is offline
Accel core card is more powerful than a non-Accel core card.
PCIe Accel cards can do more than the PCI Accel cards because of the increased bandwidth of PCIe, so I think you get more tracks and more plugin instances with PCIe cards.
For example look at the max number of plugin instances for a particular plugin ( developers often publish this... - here are Focusrite Liquid Mix HD figures : http://www.focusrite.com/products/so...pecifications/
Old 08-03-2011, 04:28 AM
BradLyons BradLyons is offline
Well on the CORE card there is a difference, actually. There are plugins that require an ACCEL card such as REVIBE. For those on an HD2 Accel or HD3 Accel it really doesn't matter, because you have that Accel Card. But for those on the HD1, it does. The reason is that the PCIE version of the Core card is actually an ACCEL card where the PCI version of the Core card was the original HD Core Card. I don't know if that changed towards the end of life on the non PCIE version or not, however. So in essence an HD1 PCIE CORE was more powerful than an HD1 non PCIE, but only in the sense of the plugins that it could power---not in raw DSP power, per say.
Thank you,
Brad Lyons
www.howavl.com
Old 08-03-2011, 12:50 PM
LukeHoward LukeHoward is offline
This is incorrect, see:
http://akmedia.digidesign.com/suppor...ower_26690.pdf
https://lukehoward.com/
FT: Accel PCIe For Core Accel PCIe acmost Buy & Sell 3 09-01-2012 03:38 PM
HD 3 Accel PCIe = 2 Accel Core + 1 HD Accel???? Eduardo Apolonia Pro Tools TDM Systems (Mac) 24 08-04-2007 02:20 PM
HD2 NON ACCEL vs. HD1 Accel Core PCIe s0nguy Pro Tools TDM Systems (Mac) 0 10-25-2006 06:18 AM
PCIE Core/Accel cards? Durka Pro Tools TDM Systems (Mac) 7 10-15-2006 06:01 PM
Runing Accel plugs on the "Accel PCIe core DaveSB Pro Tools TDM Systems (Mac) 0 12-19-2005 10:25 PM
