Able to play VSL\'s VI in Pro Tools?
I was wondering if anyone has any info how one can use Vienna's Appassionata Strings (VI) within Pro Tools? I've been wanting to stay in Pro Tools and not go back to Digital Performer (DAE problems!!!) whenever I'm programming midi. I know that VSL will one day have an RTAS version of their VI but for now, is there a way to use their AU instrument plug-in? Thanks in advance.
PT Ultimate 2024.3 PT HDX MacPro 7,1 (Intel) 16 Core 96 GB ram macOS Ventura 13.4 Somehow, musicians are now technicians! |
Re: Able to play VSL\'s VI in Pro Tools?
VST to RTAS Wrapper should work!!!!!
The Greatest Risk in Life is Doing Nothing |
Thanks for the info! Googled it and ordered!!!!
I've seen this discussed on the VSL Forum, and unfortunately, the results people have been reporting have not been encouraging. Only a limited number of instances can be used, and things are unstable. OTOH, I guess it's worth a try. You might want to do a little searching there to see what you're up against.
A far better solution would be to add a second machine as a MIDI slave (even one of the new Mac Minis would be good). It would really be great if PT added AU support, so PT users could get the efficiency and low latency of Core Audio and Midi with these types of plug-ins. Lee Blaske |
Thanks Lee. Are there any links you can provide to tutor me through the option of using another Mac as a slave? I've heard of people doing this from VSL's forum site but could not obtain any specific instructions as to how this can be done. My main computer is the G5 Dual 2.7 with 4.5 G ram. The other which I can slave is a G4 Dual 1.42 (mirrored drive doors). This would seem like a better option overall. Thanks again.
Why not convert the VSL Library to Reason Refills and use NNXT and use NNXT as a rewire slave
Should be technicaly possible? Would this be allowed under licience agreement? |
There was a good article in Virtual Instruments magazine last month about using VSL as a stand alone, and then using a Cycling '74 product to import the audio into a DAW. I think they used Logic for the test but there is no reason that PT couldn't be the DAW. Using this method they were able to access 7 GB of RAM in the Mac. I would give that a try.
Erik |
Hey Mr songman, I'm jealous of the fact that your setup works like a charm! I did some checking on this but the cost of the additional hardware is unfortunately out of my range; but thanks for the info. Seems my only option right now is to install the VST to RTAS wrapper and hope for the best... Or hope that Digi will consider the AU option, or that the VSL team releases an RTAS version of their VI.... or worst, go back to DP and expect regular crashes and other anomalies under DAE... Sure love the demo of the Appassionata Strings!
Anyone working with RAX that could shed some light as far as setup is concerned for slaving another mac to the host? Seems like this is a better option to free up some cpu issues as opposed to the VST to RTAS wrapper.
Pro-Tools won't play | Simsy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-05-2010 12:34 PM |
how to free resouces in pro tools ,pro tools cant keep up during play back | fredson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 41 | 01-26-2009 08:51 AM |
VSL's VI & ProTools : your verdict so far ? | Aquarius | Pro Tools TDM Systems (Mac) | 0 | 01-02-2008 03:18 AM |
Play by play coverage of my Pro Tools MADNESS! | test tube AUDIO | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-16-2005 06:23 PM |
my pro tools won't play! | nny | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-04-2001 11:48 AM |
