Old 03-14-2009, 01:13 PM
Johnrg Johnrg is offline
Default New User-couple of quick questions
Guys,
I have just purchased a 003 Factoryconsole, MPT2 and a new 2.66 Imac.
As you can imangine I am broke but:
(1)What are the cheap options for studio talkback. I don't need to run multiple monitors just need some easy way to talk to the talent via a four channel headphone amp.
(2)I am initially going to record to the built in Imac 360gb harddrive and backup to DVD. What, if any are the other options for back up or recording, perhaps some kind of external drive? agin think cheap if possible.
Thanks
JohnG
Old 03-14-2009, 01:47 PM
Craig F Craig F is offline
Default Re: New User-couple of quick questions
the Massy Talkback plug might work for you
http://www.smassey.com/plugin.html
It is better to record to an external Firewire hard drive with an Oxford 9xx chip set
Worst case scenario that I have seen happen:
Pro Tools records over the System folder wiping the OS out
Thank you,
Craig
Old 03-14-2009, 02:08 PM
Whiteyguitar Whiteyguitar is offline
Another way to talkback is if you are not using all the channels, just set up a mic and an audio track and when not recording you arm the track and talk, anyone with headphones will hear you. Another option that I use is, I have a mixer with SPDIF output and I plug into that and setup an audio track with SPIDF set as the input. also there is the mackie big knob.
Most definately record to an external firewire drive, aside from (worst case) wiping out the OS as Craig pointed out but it will bog down your system.
Stay true to the sound,Less is best
Old 03-14-2009, 07:26 PM
Even easier is to patch in a mic with a switch and assign it to an aux track. Leave the track up in everyone's headphones and just switch in on/off when you pick it up. When budget allows, some of the monitor/source selectors have talkback built in. I use the Presonus Central Station with a momentary footswitch and its built-in mic.
couple of quick questions! stevesound macOS 4 12-04-2013 04:00 PM
Current Axe-Fx user Very curious about the Eleven Rack - couple of quick questions Lution Eleven Rack 19 03-15-2011 10:13 AM
Couple Quick Questions BillDog793 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-17-2007 03:40 PM
Couple quick questions: TimNielsen ProControl, Control|24, Command|8 2 06-10-2005 10:10 AM
Couple Quick Questions About LE mman00 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-22-2003 08:58 AM
