Old 01-19-2007, 11:53 AM
cogan cogan is offline
Default Bring edit window forward?
How can I bring the editand or Mix window forward? The address bar is beneath the main PT window and I can't grab the window to move it ...theres got be someone who knows!
Thanks!
cogan
Old 01-19-2007, 11:59 AM
erthquake erthquake is offline
Default Re: Bring edit window forward?
'Command' + '=' (Mac)
'Control' + '=' (Windows)
Old 01-19-2007, 12:15 PM
Nope, Just tried it, although your right it does make the window active or inactive but the main PT window blocks everything from the top of the active window down to the slip and grid buttons I can't even see my counter. I can resize it .......
Thanks
cogan
Old 01-19-2007, 12:27 PM
Is the main PT window maximized? If so, try unmaximizing the main PT window by resizing. Perhaps if you resize it small enough, scroll bars will appear on the main window and you can simply scroll to be able to see the tops of the mix and edit windows.
Old 01-19-2007, 01:02 PM
yep thats it!! Thanks tell ya I've been useing two monitors and totally forgot that I had to resize in order to pull the PT window across both monitors....your a scholar and a gentleman!
Thanks again!
cogan
Is there a shortcut to bring up the Spot Dialog window? hirac Post - Surround - Video 6 03-15-2018 05:18 PM
Key Command to bring AudioSuite window to front? Irl Sanders Pro Tools 10 2 06-17-2013 05:55 PM
Is there a way to automatically bring a track you select into view in the edit window Focuret Artist Series 4 01-05-2013 01:48 PM
PT 9.0.1 Edit window view jumps forward collinsylex macOS 2 02-10-2011 12:58 PM
Bring the voices forward and extra back DCX Digidesign Hardware & Software 1 11-20-2001 11:19 PM
