Metronome/Countoff with Online Transport Issue
Hi all,
I'm having a problem I've not found before. When sync'd to tape, I can't turn ON the metronome without first taking Transport Offline, then turning on the Metronome then taking Transport Online again. Protools reports "Protools can not be put into Count Off Mode While transport is Online". I'm NOT trying to put it into Count Off mode, just turn the click on, yet it won't let me via the keyboard command or by clicking in the click icon in transport. As you can imagine, this only causes a small problem, unless I accidentally turn off the click at the wrong point in the song, and am then unable to turn it back on again. It also makes stopping and starting a bit more labour intensive than it should be. Is this just caused by some kind of linking setting somewhere than I'm missing? I'm currently on a machine running 8.05 I believe. Thanks for any insight offered. |
Re: Metronome/Countoff with Online Transport Issue
Seems like I had this issue a while back...I think we just muted and unmuted the click track.. or cmmd+click on the Click plugin (depending on your "sends" situation) Don't use that feature very often so I did not pursue it. I think it was on 8.0.1 SB |
Yes tracking drums and overdubs to tape, I've resorted to just dealing with it.
I've never had this trouble before, normally I can turn click on and off as much as I want while sync'd. Why on earth would click and countoff need to be linked? WHY ON EARTH? AVID, WHY? |
Satellite Issue when transport is online | Etienne_C | Post - Surround - Video | 11 | 03-14-2011 10:18 AM |
The countoff of the metronome | Push-Pull | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-14-2008 10:20 AM |
metronome on transport? | Blueswah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-28-2007 09:34 AM |
Metronome and Tempo Ruler on transport bar | nelsonmay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-24-2006 05:58 AM |
Shortcut for Online in Transport window? | spigots | Pro Tools TDM Systems (Mac) | 5 | 05-03-2001 12:15 AM |
