Old 12-01-2004, 10:48 AM
MUSIKxDRUMR MUSIKxDRUMR is offline
Default 1394 Error
Ever since I got the 6.4cs9 update, I keep losing connection between my 002 rack and Pro Tools... after a few minutes of working in a session, the 1394 led will start blinking (on my 002 rack) and Pro Tools freezes up? Ussually goes along with a H/W Buffer error. What can I do to fix this problem?
Also, since I got the 6.4cs9 update, a message at startup tells me that I'm not current with my firmware? The computer that uses Pro Tools is not connected to the internet, so is there somewhere I can download the latest firmware and load it onto that computer from a CD? Could that be a reason causing the above problem with the loss of connection? Thank you--
*I've bought a new Belkin Firewire Card, but it did not correct the problem.
Old 12-01-2004, 11:03 AM
Default Re: 1394 Error
1. You don't need to be connected to the internet to update your firmware.. it's an upload from the computer via the 1394 network card.
2. Which FireWire card do you have installed and have the 002 hooked up to? If it's not on the approved list, then get an Adaptec 4300.
3. If the above don't help you may have a faulty 002 power harness.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 12-03-2004, 09:29 AM
This was Digidesign's tech support email back to me reguarding the problem. It's clear what they want me to do, but VERY unclear what the heck the problem is???
You should contact tech support via telephone to set up an RA. They can
arrange to have you send it in or send you a repair kit that you you can
install your self. Call them at 650 731-6100 they will be happy to assist
you. Be sure to select to speak to someone about a repair.
Best regards,
Digidesign Technical Support
Old 12-03-2004, 09:35 AM
Chris Cavell Chris Cavell is offline
They jumped to Rail's #3 conclusion.
Cavell Studios
1394? picture. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-06-2007 09:27 PM
DIGI 002 1394 port not responding, DSI error 1092 dolby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-10-2005 10:03 AM
1115 error or 1394 led dissapear Kim Matzen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-09-2005 05:11 AM
on board 1394 or separate 1394 card PlayLoud 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-10-2005 03:50 PM
digi002, cubaseSX, radeon 9200 & 9800 ->1394 error icounil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-17-2004 02:28 PM
