Old 10-31-2004, 01:35 PM
MUSIKxDRUMR MUSIKxDRUMR is offline
Default Need help with MIDI!!!
Hello,
I am completely new to MIDI. I don't even really understand MIDI at all. BUT, that's not my question. I have a client who wants to load his tracks from a Roland VS1680 Track Recorder via MIDI. I am running PT LE through a 002. I have no clue on how to go about this process. Please help me with a step by step instruction or refer me to where I can find out how to bounce these tracks via MIDI. Thanks!
Old 11-01-2004, 08:31 PM
Default Re: Need help with MIDI!!!
First, I will make an assumption that the other guy doesn't not know midi either. If he thinks he can copy audio tracks from his Roland to anything via midi-it will never happen. Midi has nothing to do with audio as it is a set of control signals for note, note on/off, note duration, etc. If we are indeed refering to midi tracks from the Roland, I would try creating a midi track in PT and patch the midi out from the roland to the midi in on the 002. Put the track in record and play the Roland. Good luck.
Old 11-02-2004, 11:03 AM
Seems easy enough, but thats basically what we tried that day. It seem that there are quite a bit of seetings in Pro Tools that need to bed set correctly to do this transaction, but I'm pretty lost there.
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input yellow Eleven Rack 1 05-04-2012 03:33 PM
003 midi ports not there in midi studio setup? Unable to record midi now? TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-22-2009 12:06 AM
MIDI Questions On IMPORTING MIDI & Recording MIDI Pro Tools LE 7.4 Michaeldante MIDI 3 03-27-2009 05:42 PM
USB midi vs. din midi-(the old style midi connector) Ling Pro Tools M-Powered (Win) 1 02-19-2009 02:15 PM
Assigning MIDI sounds to MIDI controller and playing sounds with MIDI lalalandguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-02-2009 12:52 PM
