Old 05-04-2022, 03:25 AM
Default Re: Just got Superior Drummer 3
Originally Posted by noiseboyuk View Post
SD got an update today 3.3.0. A few significant new features including VST3 support, percussion sounds from the new EZD3 library and a new column is the midi window that has a visual representation of the groove.
Found out about the update through their Product Manager. Question: was/is there a listing of what was in the update? If there was I missed it. One thing I'd like to see and after searching their forum is the ability to move mixer channels around to arrange them particularly when you add new kit pieces and a new channel is created. Quite a few people have asked about that going on 2 years now.
Jack
QAPLA!
Old 05-04-2022, 05:11 AM
noiseboyuk noiseboyuk is offline
Here’s the changelog:
CHANGES
General
VST 3 plug-in format has been added.
Added support for EZdrummer 3 sound libraries.
The EZdrummer 2 Modern and Vintage libraries now appear in the library menu even if EZdrummer 2 is not authorized, and they are possible to authorize using a serial for EZdrummer 2 Core Library EZX.
Using the “online” method to authorize a multi-library EZX or SDX, such as Funkmasters EZX or The Rock Foundry SDX, now authorizes all parts at once instead of just the selected one. For newer libraries of that kind, the same applies to the “offline” authorization method.
Global solo/mute recall now has keyboard shortcuts Shift-S/M instead of Alt-S/M (which did not work in some hosts on Windows).
Percussion
New tambourine, shaker and one shot sounds have been added, the same that come with EZdrummer 3.
Song Track
When following host playback, if similar MIDI is detected coming from the host as is being played on the song track, the song track now stops, Follow Host becomes disabled and a small notification is shown.
Grid Editor
It is now possible to mute individual notes.
Grooves Tab
A new “MIDI” column has been added to give a rough visual overview of what the grooves contain.
In filter columns that contain several separated groups of tags, selecting a tag with a normal click no longer deselects tags in other groups in the column.
Mixer Tab
“Black Box” has been renamed to “Multi-FX” – they are most common in EZX presets and contain one or more hidden effects.
E-Drums
Many e-drum presets have been revised for improved consistency and/or accuracy.
New e-drum presets: 2box Speedlight Kit, ATV EXS Series, Medeli DD522, Millenium MPS-450, Millenium MPS-850, Millenium MPS-1000, Pearl e/MERGE.
BUG FIXES
Song Track
Dragging a fill into a smaller gap on the track now truncates the beginning of the fill, as intended, instead of the end.
If a tempo track had been imported from a MIDI file and two tempo nodes were located very close to each other, it could cause the playhead to jump away very far.
E-Drums
Hi-hat calibration could be lost when a different library was loaded.
More
Many bugs not listed here have been fixed.
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Toontrack - EZ Drummer & Superior Drummer - UPDATES Seafoam_Green Virtual Instruments 4 06-27-2016 07:07 AM
Toontrack EZ Drummer 2 & Superior Drummer Update justus1900 AAX Plug-ins 4 06-18-2014 10:14 PM
EZ Drummer and Superior Drummer Problems verticleman Virtual Instruments 5 01-02-2011 11:41 AM
Superior Drummer and EZ Drummer on sale nst7 Virtual Instruments 0 09-01-2010 09:57 AM
Ez-Drummer and Superior Drummer by Toontrack Narzugon Virtual Instruments 3 12-17-2008 08:06 PM
