Space still doesn't work on Apple M1
I downloaded the current installer just the other day, but "Space" still doesn't work on an M1 chip. Why is that ? Oh and also for some reason out of all the avid plugins, the "Air Flanger " has the same problem.
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB |
Re: Space still doesn't work on Apple M1
Bull, if you downloaded the current installer it is Apple silicon native. But how are we supposed to guess what you think the current installer is?
Space is Apple silicon native, has been since December 2012, you just need to get you act together and download the correct installer, in this case Space_2022.12_Mac.dmg. If these installers are not in your “My Products” section of your Avid account and you have a license where they should be then open a support case with Avid. Your signature says Pro Tools “2022”, 2022.12? Hopefully you are running a more recent version than that. 2023.6 or .9. And why are you spamming DUC with multiple threads about the same stuff? Please follow the DUC guidelines and create one thread for each problem. You already created another thread claiming AIR Flanger was not Apple Silicon native and I corrected that misinformation in that thread and pointed you at the correct installer version and how to use PT Prefs to check. You did not bother replying to that thread. https://duc.avid.com/showthread.php?t=426289 And now you are here wasting time repeating the same garbage. |
maybe it's because they're on OSX 10.181.1
Yep, confusing info. There is no OSX anymore. Apple abandoned the "ten" when moving to ARM, and started counting major versions from 11 (Big Sur), 12 (Monterey), 13 (Ventura), 14 (Sonoma).
Space bar doesn't play/stop in 2022.6/.7 | whataboutnoah | Pro Tools | 4 | 08-12-2022 07:32 AM |
f12 words, but command space doesn't? | hornedrum | macOS | 7 | 01-11-2015 09:28 PM |
apple - G doesn't group | Sunzate | Pro Tools TDM Systems (Mac) | 6 | 04-18-2006 11:32 AM |
Apple MP4's: Any way to work with them? | Allan Speers | Pro Tools TDM Systems (Mac) | 4 | 05-21-2004 11:04 AM |
apple-c doesn't work | protooleriate | Pro Tools TDM Systems (Mac) | 2 | 01-25-2004 03:45 PM |
