Old 07-04-2010, 02:40 AM
MccSam MccSam is offline
Default Just bought KRK ERGO and cant get it to work with pro tools! please help!
I have just purchased some new KRK VXT6 monitors, along with a new KRK ergo, I'm having trouble getting audio to play in pro-tools and I was wondering if anyone may be able to help.
I run a new mac os x with an old digi 002, I've run the ergo room tests through my new monitors and that worked fine. I've now got my monitors plugged into the speaker slots on the ergo, and then i've plugged the ergo into the 002 through the usual monitor outputs, however when I play a session in pro-tools there is no audio.
Am I doing anything obviously wrong here? Im not exactly a whiz, but I just cant figure it out.
If you could help that would be much appreciated.
Old 07-04-2010, 03:41 AM
Sparky1 Sparky1 is offline
Default Re: Just bought KRK ERGO and cant get it to work with pro tools! please help!
Start by checking your I/O and make sure our audio is routed correctly...
Sparky
Old 07-04-2010, 06:39 PM
kRokksOn kRokksOn is offline
I´ve never tested or seen the ERGO but after a quick look at their website try a few things.
1. Is ergo set up to receive analog or s/pdif? there should be a control panel for the unit, right?
2. are you using the correct speaker set? A or B
3. have you tried using s/pdif instead of analog?
Just a few things coming off the top of my head.
"Ok I promise, this is the last plugin I´ll buy!"
www.syrland.is
www.sturluson-music.com
Bought expansion, 2 different SN's neither work! mfefc Eleven Rack 8 02-04-2014 09:41 PM
Just bought MP3 option and does NOT work!! s12magic macOS 0 01-07-2014 03:14 PM
KRK ERGO with PT 8 Brian in Charlotte 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-07-2011 08:42 AM
Just bought PT 9 Crossgrade, will not work gsdesigns Pro Tools 9 1 09-04-2011 01:50 AM
Digi 001 - Just bought it, wont work, wanna cry... Jim Cobb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 12-23-2004 10:08 PM
