Toggle volume waveform view
I've been searching this forum but none of the solutions I find seem to solve my problem. According to the manual using ctrl+minus (on the numeric keypad) should toggle the view from waveform to volume but it does not work on my computer. I know it must be a mode switch or a detail I have forgotten but I can't find the way to toggle the view...
Zoom toggle is not on. Keybord focus is. Please advise |
Re: Toggle volume waveform view
just use ctlr+cmd+left or right arrow key to toggle between views. You can also hold down ctrl+cmd and click on the volume indicator, mute button, track name, pan and more to switch to that view. Hope this helps.
"Ok I promise, this is the last plugin I´ll buy!" www.syrland.is www.sturluson-music.com |
Thanks a lot kRokkson!
The first one does the trick best! I noticed that the second shortcut(s) only work in the mixer window and then you have to switch back to the arranger window, to automate your tracks. thanks again. |
Volume view toggle does´t work on auxes? | Frank Kruse | Post - Surround - Video | 7 | 01-17-2012 08:16 PM |
Waveform/Volume View Toggle Customizable? | Max H. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-06-2011 08:35 AM |
Toggle Track View not working (waveform/volume/etc) | Imgoinmad | Pro Tools 9 | 4 | 11-24-2010 04:35 PM |
Waveform/volume toggle | kingniels | Pro Tools TDM Systems (Mac) | 2 | 05-29-2009 06:47 AM |
Waveform/Volume Toggle | scot charles | ProControl, Control|24, Command|8 | 2 | 12-12-2001 10:30 PM |
