Old 05-18-2010, 02:03 PM
kyosti kyosti is offline
Angry DAE error 9131 and 9060
ok, im not even going to try to express how frustrated i am right now. I recorded about a week ago with the exact same settings and everything, and it worked fine. Now that I finally have time off, I go to record and right when I hit record then play it gives me DAE error 9131. Then it records for less than a second and DAE error 9060 pops up. I know a lot of people have had this problem, but even after taking the advice I've read - no luck. I'm using a digidesign m box 2, with mac os x, version 10.5.8 on pro tools 8. All my tracks get sent to my Maxtor 600 gig external hard drive. I've partioned a drive on it also, of which I'm using for the pro tools tracks. Please help before i break something.
Old 05-18-2010, 02:06 PM
DigiTechSupt's Avatar
Default Re: DAE error 9131 and 9060
And which advice did you take, exactly? We need to know what you've tried already...
Avid Audio Tech Support
Support FAQ
Old 05-18-2010, 02:12 PM
Well, for one, i partitioned space on my hard drive. For some reason people were saying it would be a good idea. They also said to change the volume format to Mac os extended (journaled). I think that's pretty much it. So any advice would be EXTREMELY appreciated!
Old 05-18-2010, 02:23 PM
also to note. I'm not working on a continued project. These are just simply new sessions. no matter where i try to record.
Old 05-18-2010, 02:54 PM
The Dougfather The Dougfather is offline
What are you trying to do.
Basic audio recording, tracking with plugs etc.
What happens if you lose the Maxtor out of the equation, maybe try the internal for a one track session, any better?
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Is the Maxor firewire?
iCON Photography
Old 05-18-2010, 02:59 PM
just basic audio recording. I've tried recording straight onto my mac, but everytime i do today it says:
"Session must be on an audio record volume. If permitted, set the volume(s) in question to "R" (record) in the Workspace."
It won't even let me open a session knowing it's saving to the internal hd.
The Maxtor is usb.
Old 05-18-2010, 03:04 PM
USB is a big no no because of the way it transfers info, no good for audio, it needs to be firewire. Some of those USB drives go to sleep despite the OSX setting, that will cause hangs.
With regards to workspace, follow this link, easily resolved.
http://duc.digidesign.com/showthread.php?t=141658
All the best
iCON Photography
Old 05-18-2010, 03:19 PM
thank you thank you thank you. This should've been easy, but I'm very new, and sometimes the solution is right in front of me. GAh. Also thanks for the advice on the external hard drive. that would explain all the other problems i've had before.
Thank you all, now I will try to return my head to recording mode, hopefully i have the energy to
Old 05-18-2010, 04:45 PM
kRokksOn kRokksOn is offline
Do a new partition on the whole drive (using disk utility)
You can create 1 partition only unless you want more partitions.
Use APPLE PARTITION TABLE.
Don´t use GUID partition table, that´s the one causing the problem.
turn spotlight off on the drive in apple system preferences.
Hope this helps.
"Ok I promise, this is the last plugin I´ll buy!"
www.syrland.is
www.sturluson-music.com
New Hard Driving Causing DAE Errors -9060 & -9131 David Correia macOS 20 03-12-2015 09:19 AM
DAE error 9131/9060 - PT 8.0.1 - Ext. Drive dadeedjay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-03-2011 08:58 PM
DAE errors -9131 and -9060 working from External Hard Drives asound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-15-2010 03:26 PM
DAE Error -9131.... Yes, the dreaded -9131. defconnect5 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 08-06-2006 06:54 AM
dae error -9131 William Davies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-04-2005 01:42 AM
