Old 12-30-2005, 06:08 PM
David Penick David Penick is offline
Default Working in LE7 at the Root Level
Does anyone know if it's okay to run LE 7 at the root level? Wondering if there would be advantages or disadvantages to doing this.
Thanks
Mac Mini M1 2020
Mac Sonoma
Pro Tools2024
Pro Tools Carbon
Old 12-30-2005, 06:23 PM
skycraft skycraft is offline
Default Re: Working in LE7 at the Root Level
I guess it would work fine but not having tried it myself, I can't be sure. A good question for Digi. Perhaps their developers run in root while working on the code.
I assume it could possibly eliminate some problems with file permissions. The obvious issues here are security related. You are probably aware of this. Is it going to be connected to the Internet? Will the computer log in to root at start up? During a session when you go to take a break, are there going to be people/clients around who you would rather not have access to your data? Remember, they could potentially f**k up anything on there. I would recommend against it but if you must at least use a hard to guess password.
My 2¢
It all clicks and buzzes from over here!
Old 12-30-2005, 06:27 PM
DJ Insomaniac DJ Insomaniac is offline
Forgive my ignorance, but what do you mean, work at the root level?
Sam Ejnes
Re-recording Mixer
samejnes.com | IMDb | Analog Jitter
Old 12-30-2005, 06:28 PM
Thanks. I just logged in at the root level and try to launch Pro Tools, and got an error message that said you can't run Pro Tools as root—that you have to be logged in at the administrator level. I was just curious about this. No big thang.
Mac Mini M1 2020
Mac Sonoma
Pro Tools2024
Pro Tools Carbon
Old 12-30-2005, 06:31 PM
I meant when logged on as a root user. This is the system administrator level as opposed to the basic administrator level. Some Digi support docs recommend logging in as the root to trash Digi databases and repair permissions when troubleshooting.
Mac Mini M1 2020
Mac Sonoma
Pro Tools2024
Pro Tools Carbon
no monitor level/mute working dmf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-18-2012 07:45 AM
Structure LE - Root Key? hido Virtual Instruments 2 08-05-2009 10:58 AM
cannot run Pro Tools as 'root' Dabbler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-07-2008 04:31 PM
Weird files created at root level eepmatt1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-25-2004 12:15 AM
what good is auto-rename if they don't rename at the root level? graphite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 09-28-2001 01:14 PM
