Live sound
I'd like to grab a 2 channel mix from the board with my M Box and avoid the bounce to disk, burning a cd of the band while I set up the next one. I found a thread of someone in radio wanting the same thing ( search radio ). Bastiaan said use audiosuite to consolidate and then export. I can't find these features. Nothing under audiosuite says consolidate, but under edit there is one so i used it. the only export is greyed out under file 'export selected tracts as OMF/AAF'. I have other programs but don't want to use the crappy 1/8th in and soundcard in my lappy. I always thought consolidate was so i could slide my whole track around after editing it. BTW I'm using 6.1. Thanks in advance for anyone who can help.
Tom |
Re: Live sound
ok you did use the correct consolidate because it is under edit not audiosuite.
but you should not have to even consolidate the region because it should already be one region as a whole but if u did need to consolidate it that's where it would be. next if you click teh little arrow things (not the scroll arrow) buy the bottom right hand corner of the edit window a window will pop open with ur regions list, you can just select the whole region in the pt session that you want to bounce and by doing that it will be highlited in the regions list then at the top of the regions list there is like a bar that goes across dividing that between another box which i'm not sure what goes in there because i never looked into it, well if u click the bar a dropdown menu will appear and you can choose export just make sure you export as stereo interleaved 16bit 44.1k then hit export and you can burn that file
www.klarityrecordingstudios.com |
Re: Live sound
Thank you so much. I posted not even a half hour ago and you gave me just what i needed. My glass up to all on the DUC. Thanks again.
Tom |
Re: Live sound
so, what is the diff between this and BTD? Where / how do you dither? confused:
001 - PTLE 6.4 Dell P4 2.53Ghz 768mhz Ram 160gb 7200 internal audio 20gb system 60gb storage Radeon 128mhz dual head video |
Re: Live sound
By bouncing this way, you are merely consolidating the selected region into the desired format. No volume, pan, automation or RTAS info gets added into the bounce.
Paul Peterson Sound Director The Old Globe San Diego, CA |
Re: Live sound
Just out of curiousity - does anyone ever try using alternate outputs, or even the cue mix or a y-cord off the monitor send, to record to an alternate source, say a "two-track recorder" or some other stereo recording audio program running on another computer - similar to doing a live 2-track mix in the old days? That way you could just let the session roll and do a rough mix without stopping.
- but the second mouse gets the cheese |
Getting Into Live sound | sourpoison | VENUE Live Sound Systems | 3 | 11-10-2008 11:55 AM |
Live sound | popcornmama | VENUE Live Sound Systems | 1 | 10-30-2006 01:43 PM |
OT: help with live sound | metaltim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 07-26-2005 03:45 PM |
Live sound mixing (distorted mic sound) | technician | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-25-2004 04:52 AM |
Live No Sound | SIRE | General Discussion | 0 | 02-23-2004 09:29 PM |
