Old 06-15-2010, 03:38 PM
huzzam huzzam is offline
Default can't fade: -5000 error
Hi--
I'm on PTLE 8.0.3cs2 on OSX 10.6.2. Today I opened a session from last week, and am unable to create fades, getting the error:
Could not complete your request because
You do not have appropriate access
privileges (-5000) while creating "mwe
100525" while creating "Fade Files."
I also can't do any AudioSuite processing (which would also create new files).
I just was editing this last week with no problems, and have changed two things since then:
  1. I just installed McDSP's Retro Pack today ($195 special for three days, yeah!). But I moved these out of the plug-in folder, and still can't make the fades.
  2. I moved my sessions to a new 7200rpm firewire external hard drive (Oyen Digital minipro 500gb). This drive has "ignore ownership on this volume" checked, so permissions shouldn't be a problem. I have confirmed that I can make, edit, and delete files in the "Fade Files" folder of the session, from the Finder.
Does anyone have ideas? I can create a new session and do everything just fine; everything also works in a different session from around the same time. It seems to be just this session having this problem.
Thanks
~peter in oakland
Old 06-16-2010, 01:06 PM
Default Re: can't fade: -5000 error
anyone?
Old 06-16-2010, 05:57 PM
kRokksOn kRokksOn is offline
Try creating a new session.
then do an import session data (shift+alt+I)
Navigate to the problematic session.
select all tracks,
make sure you select copy data
and import all data (markers, tempo, etc)
Hope this helps.
"Ok I promise, this is the last plugin I´ll buy!"
www.syrland.is
www.sturluson-music.com
Old 06-16-2010, 06:01 PM
Craig F Craig F is offline
Originally Posted by huzzam View Post
[*]I moved my sessions to a new 7200rpm firewire external hard drive (Oyen Digital minipro 500gb). This drive has "ignore ownership on this volume" checked, so permissions shouldn't be a problem. I have confirmed that I can make, edit, and delete files in the "Fade Files" folder of the session, from the Finder.
Go in and double check that you have write permissions to the files
if there read only, ignore ownership is a mute point
Thank you,
Craig
Error Message with Fade tool (-5000) danideluna 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-29-2013 10:09 AM
-5000 error... Help! ledogboy Pro Tools TDM Systems (Mac) 1 01-02-2012 09:46 PM
-5000 error MarkPresti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-15-2005 06:43 AM
error# -5000 bluddbank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-13-2004 08:28 AM
Error #- 5000 while verifying your Authorisation Unknown Error Help!!! Kitch Pro Tools TDM Systems (Mac) 10 08-12-2003 08:57 AM
