Old 01-18-2022, 10:35 AM
Skwaidu Skwaidu is offline
Default Can't see changes while editing Comments in Edit window on Windows OS [PT-228098]
Comments field in the Edit Window is not showing text while you type, only after pressing Enter. Typing comments via the track name dialog works fine.
Now if Avid only fixed the Windows UI, removed all the Vista/XP style borders, updated the File dialogs and got rid of the MDI/parent-child windowing design to allow us to freely move the Edit and Mix on multiple screens... (What if the Win top menu was permanently in the Edit Window, as a stopgap workaround?)
Windows 11 23H2, Intel i9-14900KS, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2024.3
Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1
HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES.
Old 01-19-2022, 01:15 AM
VijayP VijayP is offline
Default Re: Pro Tools compatibility with Windows 11
Thank you Skwaidu ! This is exactly what I was looking for. Let me try this out.
Rgds
Vijay
Old 01-30-2022, 10:08 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
I've had that Comment Field bug for over a year now. To think of it, it might have started in 2019 or 2020 though I don't remember what version of 2020 the bug appeared.
Was never a big concern of mine as long as PT worked. I'm using macOS now so I don't have that little annoyance anymore.
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 07-17-2022, 08:46 PM
take77 take77 is offline
Default Unable to enter comments in Edit view (2022.6)
Just discovered that I can't enter or edit the comments boxes when in the Edit window view on 2022.6.
When I switch to the Mix view however, I am able to click in the comment box and enter my comment.
But then the shortcut to go back to Edit view (Ctrl+ =) doesn't respond and I have to return by closing the mix view with the mouse.
I should add the session was created in a previous version. I'll test it in a new session.
A rough sea makes a smooth sailor.
Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD
Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6
Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory
Old 07-18-2022, 01:20 AM
zoff zoff is offline
Default Re: Unable to enter comments in Edit view (2022.6)
Originally Posted by take77 View Post
Just discovered that I can't open or edit the comments boxes when in the Edit window view on 2022.6.
When I switch to the Mix view however, I am able to double click the comment box and enter my comment.
Its possible that (Ctrl+ =) doesn't respond because you are still in comment edit mode. The cursor still flashing in the comment field. Hit the ENTER or RETURN key.
macOS Sonoma 14.2 Intel Core i9 MacBook Pro(16,1) 2019, 32 GB RAM Pro Tools Studio 2023.12, RME Babyface Pro
Old 07-18-2022, 02:43 AM
Thanks that was the issue when trying to get back to the Edit window.
Anyone else unable to enter a comment when in Edit view?
Old 07-18-2022, 03:18 PM
I can confirm the same here.
Old 07-18-2022, 03:32 PM
Thanks for the confirmation.
I'll test one of my newly created sessions also.
Update: Able to repro in a new session and will create a case.
Switching from MIX view to Edit via the shortcut works as it should.
Thanks zoff
Old 07-18-2022, 07:24 PM
sleepingtiger sleepingtiger is offline
If I'm understanding you correctly, this has been around for a while. In my experience, a comment can actually be entered, it just doesn't look that way. When the cursor disappears into the comment field try typing in a few characters and then hit enter. If it's the same behavior I see the comment will show after enter is pressed.
I don't remember if I had a specific case but I mentioned it to support a few years ago.
Pro Tools Ultimate 2023.9
Dell Precision T7600
64 gigs of RAM
Windows 10 Pro
HD Native PCIe
Lynx Aurora with LT-HD
Apogee
Mytek
Old 07-18-2022, 09:22 PM
That is indeed the case. I was able to type and then see the comment after hitting Enter. Although editing/deleting the comment wasn't as easy.
That also explains why the switch to Mix view shortcut wasn't responding until I hit Enter. I was unknowingly in the comment box.
I'll create a ticket for good measure and have no problem using mix view to enter or edit comments for now.
Thank you sleepingtiger
PT 12 editing issues - cursor won't move, edit window jumps. Tad Wadhams Pro Tools 12 6 02-26-2021 08:00 PM
Edit window fade shape editing idris Post - Surround - Video 4 09-07-2020 07:51 AM
Comments in Edit Window Not Working in 12.7 DAWgEAR Pro Tools 12 7 01-24-2017 01:50 PM
> Comments Window unreadable will editing Howardk Pro Tools TDM Systems (Mac) 13 02-01-2014 01:41 PM
Editing Portamento in PT edit window? kirkbross MIDI 1 02-11-2009 07:05 PM
