  #21
Old 01-26-2022, 07:37 AM
bluecataudio's Avatar
bluecataudio bluecataudio is offline
Blue Cat Audio
Default Re: Blue Connector Allows Routing between apps or DAWs or networked computers
Originally Posted by johnsimmons View Post
i'm on mojave but got the same concept working on Logic Pro X 10.5.1, just a bit overkill to host a single plug to output to the airpods - i'm sure there must be another mini host going forward
It is indeed a bit overkill. It's not free but you could use PatchWork to do that too.
It is quite useful as a monitoring solution. You can use a similar setup when monitoring on headphones with a correction plug-in such as Re-Head, if you don't want the plug-in to sit on Pro Tools' master bus (which may be a problem if you forget to de-activate it before exporting a mix...).
HTML code is On
Routing other apps to Pro Tools freakhouse Pro Tools HDX & HD Native Systems (Mac) 11 10-04-2021 10:04 AM
Routing Arp Kirnu with Blue Patch Work megahias AAX Plug-ins 2 10-08-2016 05:41 AM
Can you run 2 different DAWs on 2 different computers and link them up? [email protected] Pro Tools 10 7 11-12-2014 11:36 AM
Routing audio from CoreAudio apps to Pro Tools stargazer macOS 7 05-02-2013 09:55 PM
routing other audio apps through mbox? sterndrup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-05-2008 10:13 AM
