Old 08-13-2015, 12:43 PM
senghor senghor is offline
Default i/o settings so that they not change
Hi!
I have starting using PT 12.1.
I open my sessions that I have recorded with PT 11.3. They open nicely with no problem, but they open with i/o settings they were originally saved.
BUT my i/o settings changes all the time. How can I set an i/o setting in PT 12.1 so that it always stays the same.
Thanks for your help!!
Old 08-13-2015, 01:04 PM
AlexLakis AlexLakis is offline
Default Re: i/o settings so that they not change
I know Pro Tools 12.1 has a new I/O settings menu, so I'm not sure if there's a new way to do this, but the way I've always done it is to Save the I/O config you want and load it as needed. Maybe a more elegant way exists, tho? Like a "force to default"?
Old 08-13-2015, 01:41 PM
Thank you for your reply.
Is there other possibilities to do this?
Old 08-13-2015, 03:45 PM
Every time you open a session with old settings, or with settings from another studio, you will have some "repair work" to do. Open the IO setup page and select the BUS tab. On the right-hand column, click at the top, then click a second time. That will move all output routing paths to the top. all that are in italics are non-working paths and can be deleted. Then double-check your usual main output(and you may need to rename it back to your normal path name). That should clear up most all the issues, and once you've done it a few times, it will go faster(and make sure you don't have it set to "sessions overwrite IO settings")
Old 08-13-2015, 04:03 PM
ALBEE,
Thank You. I will try/do that on monday whrn I will be back on my PT 12.1.
Regards,
Kari
Old 08-13-2015, 04:11 PM
Albee,
I am running PT 12.1 with Mbox3 (no other interface or pre) apart my Keystation 49e that I run USB). What is your recommendation with the new PT12 for I/O settings? What configuration for INPUT and OUTPUT?
Is there something to know apart the PT10 or PT11 i/o settings?
Thank you for your help!
Kari
Old 08-13-2015, 08:42 PM
Originally Posted by senghor View Post
Albee,
Kari
Nothing special to change between 10/11/12(for me). I name my Inputs for what preamps are connected(like Vintech1, Octopre1, ISA-4, etc. My outputs are labeled for what they feed(like Main Out L/R, Phones Drums, Phones Bass, etc)
Change i/o Settings? shultzee13 Pro Tools M-Powered (Win) 0 07-14-2010 02:48 PM
How to change the I/O settings??? (Output) joeytpg Pro Tools M-Powered (Mac) 3 01-17-2006 11:06 AM
Can Change IRQ settings in Bios Can't From within XP PRO TallCat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-01-2003 06:42 AM
How do you change IRQ settings in XP Pro? Calvin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-20-2002 12:48 AM
how to change scsi settings Jepse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-12-2002 08:23 AM
