#31
Re: Need Help Bad
How much did they charge you? I had a similar issue with a 192 I/O AD card years ago, and I think I paid a flat rate of 200.00 back then, but that was when the card were going for 800 used so it was a no brainer.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
#32
Re: Need Help Bad
yes, out of warranty. probably happened 2010 maybe 2011
I don't remember how much it was (seems like it was sub $200 but wasn't out of my pocket) just that was falt rate so you know the cost up front Probably need an ASC now to get a quote also the photo of the back edge with the bar-code sticker, is it bent up or is that heat damage? looks like heat damage to me
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
#33
Re: Need Help Bad
I was able to get it to run Digitest on just the Core card and it was installed in the forth PCIe slot, with the video card in slot 1. All seems to be centered around DSP B, of course I have no idea what that means.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp Last edited by Barry Johns; 01-25-2015 at 09:42 PM. |
#34
Re: Need Help Bad
The only irregular viewable discrepancies with the Core Card vs the other two accel cards is the discoloration around the grounds.
See Pics: Here is a pic from one of the Accel cards as a reference.
#35
Re: Need Help Bad
It's just bent up, that is the original clue discoloring a little, no sign of any issues with that.
#36
Re: Need Help Bad
to get a repair http://avid.force.com/pkb/articles/en_US/faq/en210711
#37
Re: Need Help Bad
#38
Re: Need Help Bad
That's DSP chip number? I've had this on 2 cards over the years and no practical way to repair the card. I found the card will still work fine as long as I disabled that DSP chip before loading and session! I think it's option click (or similar) on the chip in the usage window to make it disabled etc. If the mixer it certain plugins got assigned to that chip it would make noises and clicks etc. Chris
#39
Re: Need Help Bad
did I not have a good attitude ? at some point while posting I am always in good mood, maybe a old posting came off wrong? I'm sorry
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
#40
Re: Need Help Bad
I received my replacement core card from RSPE on eBay with 6 month warranty for 424.00. Back up again!
Will send my non working one to see if it can be fixed next week. Thanks to all for trying to help me!
