Can't hear MIDI until playback
Hello
I have a Roland 88 key grand piano with built in MIDI. It's worked fine up until last week. I have not changed any settings whatsoever. I cant' hear any MIDI going through my speakers yet when I hit record and play it back You can hear it. No levels are appearing either yet there is MIDI sound.
Macbook Pro Mac OS 10.10.3 Mbox 2, Pro Tools 11 |
Re: Can't hear MIDI until playback
Options > MIDI Thru
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Well the first thing to clear up is that MIDI itself has no sound, rather it's just information. Assuming you are wanting to play a VI, vs the sounds on the Roland - a couple of things to check would be that you have MIDI thru selected in PT, that you have the MIDI port the Roland is connected to available as an input device. Then, check your I/O in the session, that you have the track assigned to an instrument.
If none of that helps, you may need to explain your situation a bit more... Such as, are you hearing the instrument while you are recording or only at play back?
Lincoln Mitchell Pro Tools | latest Mac Mini Server | OSX | Current 16GB Ram | SSHD Apogee Ensemble Thunderbolt |
I explained in my first post that I have not changed any settings and have not disconnected anything. Midi pass thru has always been turned on and I have never had this problem till last week. I only hear the MIDI during playback. In record mode no levels appear but yet after playback you can hear it but still no levels appear.
Are you playing a VI? Are MIDI Clips being recorded? Describe your session, using MIDI Tracks, Instrument Tracks, Auxs? Explain routing...
Yes I'm sometimes using xpand2 or another VI in pro tools and sometimes using Reason Rewire. I have my Instrument track routed to a submix. MIDI clips are being recorded.
I have a midi keyboard and electric drum kit...I can only hear drum's midi playback | thrice506 | MIDI | 0 | 02-09-2014 11:18 AM |
I can't hear MIDI Playback. | YichenWang | Getting Started | 1 | 12-30-2013 02:47 AM |
Can't hear anything from midi playback...... | the viking | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 02-16-2007 05:56 AM |
Can't hear midi playback | msmusic | MIDI | 3 | 02-20-2006 06:54 PM |
Can't hear MIDI playback | Qwack | MIDI | 1 | 01-12-2004 11:24 AM |
