Old 06-11-2010, 02:08 PM
sonicapg sonicapg is offline
Default TDM 6.4 With EIDE SATA?
Hello
This is kinda noobie question but I search the net and couldnt find me an answer.I know PT 5.X TDM needs scsi drives for audio ,does PT 6.4 TDM also needs scsi only for audio? how about eide and SATA?
Old 06-12-2010, 04:20 PM
Wireline Wireline is offline
Default Re: TDM 6.4 With EIDE SATA?
I'm running one TDM system (6.2.2) to a firewire drive...so I believe it all depends on what your actual machine is setup to handle. Haven't tried SATA, as I don't believe SATA was a popular (or even available?) platform when 6 was first released.
Disclaimer - all speculative...All I know as fact is that Firewire 400 and 800 work on Mac G4s and are rock solid.
Ken Morgan
Midland, TX
It Doesn't Matter What I Did Then - What I Do Now Is What's Important
2017 Intel Mac Mini, 32G, PT 2023.12 Studio, Presonus Quantum 2626 and a bunch of stuff via ADAT
Old 06-12-2010, 05:18 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
SCSI was only a requirement for the disk i/o(pro tools iii) systems. The d24 and mix systems will run a session from any drive, they are just recommended to use SCSI because that was the fastest and most reliable drive at the time. But things have changed a lot in the last 15 years. Depending on your computer, you should be fine with a dedicated IDE drive for audio. I haven't personally tried SATA, but I've heard it works, though there may be some SATA PCI cards that are better than others...
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
SATA vs. EIDE kmank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-12-2007 06:11 PM
External HDD - what is better - SATA/EIDE/ATA propofol 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-28-2007 09:11 PM
6085 Errors and SATA and EIDE drives seths 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-08-2005 07:15 PM
Sata/Eide hfd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-06-2005 05:08 PM
sata/eide hfd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-05-2005 09:22 AM
