Old 12-05-2008, 04:32 AM
sterndrup sterndrup is offline
Default routing other audio apps through mbox?
am i correct in assuming that other audio apps like media player cannot be routed through the mbox.
i have looked in the control panel under "sounds" and cannot find this option
i read about the asio wave driver...but not sure. it reads to me like this cannot be done yet. also checked other posts on this issue
i have vista software
thx
Old 12-05-2008, 06:02 AM
jmitchell1532 jmitchell1532 is offline
Default Re: routing other audio apps through mbox?
If you go into the Start Menu of Windows, Control Panel, Audio, you can change the audio driver to the Mbox, but I wouldn't suggest it. I tried it with ITunes and the latency caused songs to sound distorted and choppy. So, if I want to listen to music that isn't in Protools, I plug my headphones into my comp.
Old 12-05-2008, 06:12 AM
sbag sbag is offline
Jmitchell is correct , but the issue with itunes < being choppy > is a known issue and has been known since 7.6 or 7 i forget.
But you can route out of the mbox,
Gear>
C8, 002, Trigger Finger, Kontrol 49, Apc 40
SW >
Pt 8, Reason 5, Recycle 2.1, Ableton Live Suite 8.02
Plugs >
All Registered plug in's & Vinyl out the wazoo. Mp3 sucks
Old 12-05-2008, 10:13 AM
DigiTechSupt's Avatar
Unfortunately there is NO Wavedriver for Vista yet - you can only use your Digidesign hardware for playback from applications that support ASIO.
Avid Audio Tech Support
Support FAQ
Routing audio from CoreAudio apps to Pro Tools stargazer macOS 7 05-02-2013 09:55 PM
MBOX is slowing my audio in Final cut and QT Apps (help?) nelsonmay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-12-2008 02:21 PM
MBOX is slowing my audio in Final cut and QT Apps (help?) nelsonmay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-11-2008 08:49 PM
MBox SPDIF I/O w/Third Party Audio Apps? (OSX) Robert George 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-06-2003 06:53 PM
Mbox audio in with apps other than PTLE Mitch Turner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-12-2002 08:30 AM
