Old 04-28-2009, 02:18 PM
central node central node is offline
Default "Cannot complete the Bounce To Disk Command"
The other day i tried bouncing a song 16 bit wav., stereo interleaved. However at the end of the bouncing a box popped up in the center of the screen with a white X in a red circle in the corner of the box that said symbol for symbol the following:
could not complete the "Bounce to Disk..." command because: Assertion in "\code\azores_Handel\AlturaPorts\NewFileLibs\FF\Au dio\FF_AudioProperty.cpp", line 33.
I have done nothing different in my usually successful bouncing process. Is there an update or fix that i need for 6.4 LE that fixes this problem? I did just re-build this computer and we've been fixing bugs along the way with our tech guy. This problem just popped up since we got our remodeled pc back in March.
Does this ring a bell for anyone running PT 6.4 LE on a Windows XP PC?
Thanks,
Eric
Old 04-28-2009, 04:57 PM
Default Re: "Cannot complete the Bounce To Disk Command"
I would update to cs9 and then delete the prefs folder and reboot. Refer to this thread for more info and advice:
http://duc.digidesign.com/showthread.php?t=133039
"could not complete the bounce to disk command because File or folder not found (-43) Lubbi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-05-2013 04:49 AM
Could not complete the Open Session..command Assertion "KeyContextRegistry" line72 JLiRD808 Windows 4 12-25-2012 01:01 PM
Help with "Could not complete the exit command because Access Violation occurrred" keithl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-06-2010 06:24 PM
Error: "pro tools could not complete the import audio command because assertion in" elsterNJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2009 09:38 AM
"Could not complete the open the session command because Magic ID does not match." willyrmc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-10-2003 01:47 PM
