Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 11-12-2009, 05:57 AM
fransmo fransmo is offline
Default PT 8 startup problems
1. How can I have groups deactivated when opening PT? Evrytime I open up PT I have to manually deactivate the group function to be able to adjust one slider without all the others following. Clumsy and irritating. Is there anyway to avoid this?
2. I also have to manually deactivate "digitranslator" loading during the load process. Can I get rid of this?
There you are, two small but silly things!
/fransmo
Old 11-12-2009, 03:04 PM
DigiTechSupt's Avatar
Default Re: PT 8 startup problems
Shift+Command+G = Suspend all Groups.
You can find many more keyboard shortcuts in the Keyboard Shortcuts Guide under the Help menu in Pro Tools.
Remove the OMF.dll from your Pro Tools folder.
Avid Audio Tech Support
Support FAQ
Problems on startup Spydogen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-20-2007 01:14 PM
StartUp Problems MusSickIzLife 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-27-2004 08:02 PM
002 startup problems svenu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-21-2002 10:05 AM
G4 733 / OS 9.2.1 startup problems!!!!!!! electroluky Pro Tools TDM Systems (Mac) 16 03-21-2002 12:14 AM
startup problems dans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-06-1999 07:39 AM
