Re: Core Audio Manager, Pro Tools 8 LE, and I-tunes/Quicktime/etc.
I am also having problems with core audio with Pro Tools 8
I have an HD3 system. Its seems that: 1 Core audio will not work at all with Quicktime 7.6. No audio. 2 When you get core audio to work with Itunes etc. then subsequently lunch PT with video in the session it takes 5 seconds for the transport to respond. Ie when you press start nothing happens for 5 seconds. The only solution to this is to delete the preference files in on the system drive in the folder: Library/Preferences: com.apple.audio.DeviceSettings.plist com.apple.audio.SystemSettings.plist com.apple.soundpref.plist Then its works ok once you do a restart and relaunch PT but core audio will not launch automatically after that and will not work with itunes until you goto 'sound' in System prefs and select Digdesign HW (HD) Anyone got any ideas? |
Thanks for your response.
I tried the toggling, actually this is what you have had to do for the longest time. I still get no audio from QT with Core Audio athough If you select internal speaker it works. Deselecting 'Digi HW' solved the 2nd problem with video in the session. PT plays correctly when you do this. Hope we can fix QT issue. Thanks. |
Just do what I do and run a 1/8" stereo cable to split 1/4" or RCA out into your 002 and hit the ALT/SRC button on the front and WALLAH!! it works.
No Core Audio needed.
Mac Pro Dual Quad 2.8Ghz 2008 MacBook Pro i7 2012 OSX 10.8.5 - OSX 10.7.5 Pro Tools 10.3.7 - 11.1.2 6GB RAM Universal Audio Apollo Quad!!! Eleven Rack Focusrite Octopre MKII Yamaha HS80s Rockit RP5 Monitors w/ RP10 sub |
Great idea for this work around, however all inputs are being used.
I am sure there must be a way to get core audio to work with Quicktime. It worked before I upgraded to QT 7.6 |
#16
Use VLC for videos and Itunes for Audio... Seems to be working for me running Digi 003 Rack , Leopard 10.5.5. Hope this helps! Seems like QT for now is almost useless It works maybe 5% of the time with hours worth or effort. But VLC supports almost any video file format so Cheers!
#17
In other words... time to switch to Logic. |
002 pro tools 10.3.5 Avid Core Audio Manager not working with safari or iTunes? | nate9 | FireWire & USB Audio Interfaces (Mac) | 1 | 07-19-2013 07:25 AM |
Quicktime multich playback with Audio Core Manager | DannyVanSpreuwel | Pro Tools TDM Systems (Mac) | 3 | 04-13-2009 12:03 PM |
noise in i tunes through Core Audio Manager | relgato | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-02-2006 10:57 AM |
core manager and 5.1 quicktime not working | john1192 | Pro Tools TDM Systems (Mac) | 2 | 07-29-2006 05:29 PM |
I-tunes 4 and 001 core audio on osX | bzldzl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-01-2003 05:07 PM |
