Old 10-17-2021, 07:00 PM
Extreme Mixing Extreme Mixing is offline
Default Export Playlists to new audio tracks
There must be a simple, one step, clean way to do this, right? I have a client who sent me 40 vocals in a playlist to make a huge kids choir. For now, I'm giving up and doing them one by one, but there must be a better way, right??? If not, there should be.
Steve
Steve Shepherd
Extreme Mixing
Old 10-18-2021, 08:44 AM
Default Re: Export Playlists to new audio tracks
If they all start at the same time, create a new session and Import Audio. You will then have the option of putting all the files in the Clips Bin, or on New Tracks(what you want).
Originally Posted by Extreme Mixing View Post
There must be a simple, one step, clean way to do this, right?...
I don't think there is, but maybe someone else can think of a way, and yes, there should be. Playlist management is such a mess...
If it's something you do a lot you could probably come up with a Soundflow macro to take care of it, but for a one off it's not worth it.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 10-18-2021, 08:57 AM
Thanks guys. Next time I'll take Albee's advice and consolidate the audio from the top and reimport the new audio to new tracks. I spent more time looking for how to do it than it took to just copy paste and label the tracks! I did learn a few cool tricks along the way thought, so it wasn't time wasted.
Steve
Steve Shepherd
Extreme Mixing
Old 10-18-2021, 09:08 AM
The Weed's Avatar
The Weed The Weed is offline
How was the recording done? If it was done using Loop Record and Expanding Alternate Takes To New Playlists, if you get the original session, you may be able to use this (from the Reference Manual):
"Expanding Alternate Takes to New Tracks
Expanding alternate takes to new tracks readily facilitates auditioning, editing, and mixing alternate takes, each on separate tracks. To expand alternate takes to new tracks:
1 Identify the clip on the main playlist with matching alternate clips (takes).
2 Do one of the following:
• Right-click the clip and choose Matches > Expand Alternates To New Tracks.
• If the clip is selected, with the Selector tool, Command-click (Mac) or Control-click (Windows) anywhere on the selected clip and choose Matches > Expand Alternates To New Tracks.
• If the clip is not selected, with the Selector tool, Command-click (Mac) or Control-click (Windows) at the precise beginning of the loop or punch range and choose Matches > Expand Alternates To New Tracks.
3 Then choose one of the following from the Expand Alternates To New Tracks sub-menu:
By Track Name Names all new tracks after the source track name.
By Clip Name Names each new tracks after the corresponding original clip names that you see in the Matches list.
By Track and Clip Name Names all new tracks after the source track name, but with the corresponding original clip names in parenthesis.
All matching alternate clips are copied to new tracks."
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 10-18-2021, 11:12 AM
Thanks for posting that. I found that but couldn't get that to work in the way I expected. It made a new track with the same playlists, and did not put each playlist on it's own new audio track. I tried a few times, but never got what I wanted.
Have you been successful with the method?
Let's face it, takes are usually for comping, but this time was different. Consolidating the audio and then reimporting to the session works way more as expected and does the labeling automatically.
Steve
Steve Shepherd
Extreme Mixing
Old 10-18-2021, 01:36 PM
Make 40 new tracks, then put the source track into playlist view, highlight all of the clips on the playlists, and control-drag them down to the new tracks? This works in my head, but I'm not sure if it will IRL.
Scott Gatteño
Old 10-18-2021, 01:57 PM
Tweakhead Tweakhead is offline
Originally Posted by originalscottyg View Post
...This works in my head, but I'm not sure if it will IRL.
possibly the best line in DUC history !
Old 10-18-2021, 02:05 PM
EGS's Avatar
EGS EGS is offline
Click for audio/video demo
Click for resume
Old 10-18-2021, 02:52 PM
the really funny thing is, like Scott - this totally works in my head too.
I don't even wanna actually try it for fear of disappointment.
No audio in frozen tracks after export selected tracks to new session PierrevC Pro Tools 2018 4 11-14-2018 03:33 PM
12.8.2 Export tracks as session with audio is offline Frank Kruse Pro Tools 12 0 10-24-2017 12:42 AM
Import / export between aux and audio tracks. Audioartist macOS 1 09-10-2012 02:52 PM
How to export playlists? Exporting comp tracks? Hugelittle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-16-2011 08:16 AM
Importing multiple tracks to 1 audio track for playlists DonaldM Tips & Tricks 6 08-01-2010 08:15 PM
