Old 09-24-2018, 02:14 PM
nfitzhugh nfitzhugh is offline
Default Problems with AAFs from Davicini Resolve 15
I'm having an impossible time exporting anything that my ProTools sound mixer can use. The AAFs Resolve 15 are generating are missing automation which is a big problem. Has anyone solved this??
In reading other posts, I though I would try exporting an XML for FCPX and then using X2Pro Convert to generate the AAF but every time I try to create an XML, Resolve crashes. We have also tried exporting an XML for Premiere and then generating an AAF in Premiere but lots of clips are missing, etc, when we use that approach.
This is such a basic need with any NLE, how could this not work especially when there is a ProTools export present actually built into the Deliver module??
Has anyone found a reliable way of getting an AAF out of Resolve for ProTools or just getting the audio out in any usable way?
Old 09-28-2018, 03:17 AM
trevora trevora is offline
Default Re: Problems with AAFs from Davicini Resolve 15
I’d recommend posting this on the Blackmagic forums, it’s going to be their issue & Im sure they are keen for interoperability.
Old 09-28-2018, 07:45 AM
Thank you. I have posted it on the Blackmagic forums too. In conversations with Blackmagic tech support though they have suggested that I bring this up with Avid...
Old 10-03-2018, 12:37 PM
Scott G Scott G is offline
Please keep us updated on your progress. some editors I am working with are thinking of switching from Premier to Resolve.
Scott
Auckland New Zealand
PT2022.5 Focusright RedNET 8Pre, RedNET R1
Z690 AERO D Workstation, I7 3.6GHz 12 core, 64GB RAM, Win10 Business 64bit
Old 10-03-2018, 01:55 PM
Will do.
HTML code is On
DaVinci Resolve AAF problems reichman Post - Surround - Video 19 03-08-2019 12:41 AM
Clipgroups/crossfades and AAFs ErikGuldager Post - Surround - Video 1 03-27-2018 10:37 AM
Opening AAFs across network? philip_purcell Post - Surround - Video 10 06-18-2013 03:48 AM
Recuts- analysing changes in aafs Moviesound Post - Surround - Video 11 06-28-2012 06:44 AM
MXF audio in AAFs colinato Post - Surround - Video 8 09-18-2011 12:39 AM
