Old 04-22-2009, 08:25 AM
Achermann Achermann is offline
Default Pro Tools 8 HD crashes when opening 7.4 sessions
I am having problems opening an important session from Pro Tools 7.4 HD, but Pro Tools 8 HD crashes everytime I try to open it.
I have tried repairing permissions and trashing prefs, and it has not worked.
Does anyone have an idea of what is going on - and how to fix it?
Old 04-22-2009, 10:45 AM
DigiTechSupt's Avatar
Default Re: Pro Tools 8 HD crashes when opening 7.4 sessions
Where is it in the launch process when it crashes?
Biggest suspects would be incompatible plug-ins. Try pulling all your plug-ins from your plug-ins folder and launch again. If it launches, you'll know it's a plug-in at fault.
Also, you could try using Import Session Data to import tracks one by one until you identify the one causing the crash, then try to recall what about that particular track could be causing problems.
Avid Audio Tech Support
Support FAQ
Old 05-24-2009, 09:50 AM
dieselsynth dieselsynth is offline
One addition to the above. After figuring out which plug-in it is by importing one by one (or if you just don't have the patience and need to get the session open quickly:
Hold down the Shift key while opening the session. This will deactivate all plug-ins. At that point remove the plugin from the suspect track and you're good to go.
I've found that Amplitube is a usual suspect for all you LE users out there...
Old 05-24-2009, 11:35 AM
Were these sessions saved on the same system or a different platform? Same processor type? Sounds like a preset endian issue.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 05-24-2009, 12:24 PM
holden holden is offline
It may be easier to help you if you reveal more about your system architecture, plugins, and session. For instance, if you are using an Expansion|HD chassis and opening a 96k session with more than one instance of Altiverb in it your session may crash upon attempting to open it in PT8 due to a current Altiverb bug.
First make sure all your plug-ins are current and see if that fixes the problem. If not, post your OS version, PT version, hardware setup, session sample rate and bit depth.
PT9.0.0, 3.0GHz Mac Pro, OS 10.6.3, 13GB RAM, HD6/Accel, Magma PE6R4, PRE
Old 06-26-2009, 07:02 PM
dexter808 dexter808 is offline
Reviving this thread as I have the same problem. Just upgraded today and PT will load my old sessions (7.2) but will crash very soon after. In fact the crash is so hard force quit wont work so I have to hold down the power button on the front of the computer.
Anyone figure out what is causing this?
Dual G5 2.0 pci-e
10.5.5 fresh install
PT 8.0 cs3 fresh install
NO third party plugs installed yet.
Thanks.
Old 06-26-2009, 07:20 PM
s.d. finley s.d. finley is offline
Did you trash your old digi databases? That free app will do that and more preference wise.
sdf
www.sugarhillstudios713.com
Pro Tools 7.3.1 crashes when opening sessions Curt S 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-02-2007 10:32 AM
Opening Old PT sessions crashes PT 6.7 SkiMan Pro Tools TDM Systems (Mac) 3 08-01-2006 08:13 PM
PT 7.1 Crashes when opening sessions. gwattaloopy1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-19-2006 06:46 PM
PT7.1 crashes when opening PT6.4 sessions LeGato Pro Tools TDM Systems (Mac) 2 03-08-2006 10:10 PM
PT 7.1 Crashes when opening legacy sessions tomcat Pro Tools TDM Systems (Mac) 2 01-23-2006 02:57 AM
