The session is saved on a volume set to \"Transfer\" only...
If you are using Windows XP, you need to be sure your new data disk is configured as BASIC and *not* DYNAMIC!
Check this Microsoft link for more detail on the difference: http://support.microsoft.com/kb/314343 DYNAMIC disks are for situations where you are going to be doing RAID, etc. Pro Tools doesn't seem to play well with such disks. So configure your disk as BASIC *before* making any paritions and formatting them: "Control Panel" ---> "Computer Managment ---> "Disk Management" ---> "Properties" of the new disk Obviously, if you already have data on that disk / partition, be sure to back it up first, then write it back out after you've made the change.
Pro Tools 2023.6 & 10.3.0 Windows 11 Professional / 64-bit Roland Octa-Capture |
Re: The session is saved on a volume set to \"Transfer\" only...
I believe this applies to windows XP proffesional only (not home)
How does this relate to the topic of transfer volumes?
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
PT set my DYNAMIC volumes as "Transfer" only in the Workspace option - it would *not* let me change them to "Record" or "Playback". Changing to a BASIC disk fixed this.
And yes, this was XP Pro - don't know about XP home. Hey, it worked for me!
Out of curiousity, would something like this also allow you to change the status of say a removable drive such as a USB Flash Drive from T to R?
Macbook Pro 15" (Mid 2014) 16GB RAM 512GB SSD Pro-Tools 12 2.5GHz i7 Quad Core |
This only related to hard disks that are supposed to allow R and P yet show up as T due to wrond format mentioned above. You cannot use USB flash drives for recording as they are just too slow.
Session saved on a volume set to Transfer only? | alexanem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-17-2023 03:22 PM |
Session saved on "transfer" only volume | mcm15 | Pro Tools M-Powered (Win) | 4 | 05-24-2013 11:58 AM |
Help! "Session is saved on a volume set to 'Transfer' only" | nuemes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-06-2011 05:46 PM |
Session saved on a volume set to "Transfer" only | Gilles D | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-02-2009 02:19 AM |
Error Message: This session is saved on a volume set to Tran | ckboddic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-18-2007 09:24 AM |
