Old 02-09-2005, 07:58 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools 6.4.1cs3 Update for MIX Systems
Pro Tools TDM 6.4.1cs3 Update
For Pro Tools|24 MIX Systems with Pro Tools 6.4.1 on Mac OS X and Windows XP
Now available for download:
http://www.digidesign.com/download/cs/641cs3
What's Fixed in Pro Tools TDM 6.4.1cs3?
In addition to all previous 6.4.1 CS fixes, Pro Tools TDM 6.4.1cs3 contains the following:
Fixed: Launching or Creating a Session with More Than 16 Mono Bus or Output Paths May Result in a Crash (Item #57053)
  • This crash would only occur when all active bus paths were mono (no stereo paths or mono sub-paths) and a Surround Mixer plug-in was installed.
Linked from the Index of Pro Tools CS Downloads, at the top of Support/Downloads:
Administrator
Old 02-17-2005, 02:09 PM
Noiz2 Noiz2 is offline
Default Re: Pro Tools 6.4.1cs3 Update for MIX Systems
OK now I have the "this program needs to work on 47 tracks" digi plugin bug/issue. I'll search because I heard this discused before somewhere but if anyone knows off hand what the fix was please let me know.
Thanks
www.scottkouesound.com
SK
Old 02-19-2005, 12:03 AM
gugu gugu is offline
Thanks
It's a Waves issue. When you open a plug without closing the Waves plug window, you get that message.
Solution: close the window and reopen the other plug from menu bar.
This Waves bug exists since V3 so it was.....xx years ago
gugu
Old 02-19-2005, 12:20 PM
Thanks for the info. Unfortunately I don't have any Waves plugins, and I was opening the Digirack plugin with no plugin windows open.
SO the quest goes forward. I did a bunch of DUC searches and haven't found anything on this "issue". Digi any help?
Thanks
SK
Old 03-04-2005, 12:47 PM
egedney egedney is offline
Default Re: Pro Tools 6.4.1cs1 Update for MIX Systems HELP
Digi I hope you're reading this. The cs 1 update has NOT FIXED the following:
Fixed: When Using Pro Tools in +12 dB Fader Gain Mode, the Level on Outputs Could Be Incorrectly Increased by Up to18 dB
(Item #54461)
Creating a large session where the mixer is spread out over multiple DSPs could result in output levels increasing by up to
18 dB.
I've tried updating with cs1, cs2, and cs3 and I'm still having the problem. I've gone thru everything: Creating new session of importing all my session data, trashing prefs, deinstalling the program and reinstalling it. I'm still having this problem. I'm using a G4, 1.3 dual Ghz. OS X.3.4. 6.4.1cs3. I'm using 3 888/24's. This effects my sessions if they are only 18 tracks. If I have a session that's only 8 tracks it doesn't seem to jump in level. But my sessions have to have 32 tracks with Audio on most tracks.
I have to go to a film mixing stage in a week and I can't have the pro tools having these random outputs for the final film mix. PLEASE HELP.
Pro Tools LE 7.3.1cs3 Update for Mac OS X Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-01-2007 05:13 PM
Pro Tools 7.3.1cs3 Updates for All 7.3.x Systems Avid Technical Alerts 0 06-01-2007 03:09 PM
Pro Tools HD 7.1cs3 Update Avid Pro Tools TDM Systems (Win) 0 01-20-2006 07:05 PM
Pro Tools 6.4.1cs3 Update for MIX Systems Avid Pro Tools TDM Systems (Win) 0 02-09-2005 07:59 PM
Pro Tools 6.4.1cs3 Update for MIX Systems Avid General 0 02-09-2005 07:44 PM
