Old 10-19-2021, 07:45 AM
Default Re: Export Playlists to new audio tracks
Ha! You guys are hilarious. This made my day!
Scott Gatteño
Old 10-19-2021, 07:53 AM
Ok, so after all that , I had to know. I just tried it and it works fine. I opened up the source track to playlist view, used the selector to drag across all the playlists, highlighting all the clips, then used ctrl-option-drag (Mac) with the grabber tool to drag a copy of all of the clips to the new tracks. Omit option if you don't want to keep a copy on the playlists. Unfortunately automation from the main track lane doesn't carry over, so that would have to be a separate process of "copy all automation" and paste to each track after the fact.
Scott Gatteño
Old 10-19-2021, 08:09 AM
Ben Jenssen's Avatar
What about track names?
You had to rename them didn't you.
I'd think that would be less of a problem using albee's method of dragging clips onto the edit window to create new tracks.
Old 10-19-2021, 08:19 AM
Good point. I think a Batch Track Rename could tackle that pretty easily, but dragging from the clip list could also work. However, if there are multiple clips and punch-ins on a playlist, I'd feel more confident using ctrl-drag to maintain timing/overlap/etc. than using auto-spot from the clip list.
Scott Gatteño
Old 10-19-2021, 03:31 PM
Extreme Mixing Extreme Mixing is offline
It was not like they were all called by the same name. young girl, breathy girl, boy 1, 2, 3... And I wanted those names. Consolidate Audio and then import to new tracks is the way to go for this one.
I'm still surprised that there is no other way.
Steve
Steve Shepherd
Extreme Mixing
No audio in frozen tracks after export selected tracks to new session PierrevC Pro Tools 2018 4 11-14-2018 03:33 PM
12.8.2 Export tracks as session with audio is offline Frank Kruse Pro Tools 12 0 10-24-2017 12:42 AM
Import / export between aux and audio tracks. Audioartist macOS 1 09-10-2012 02:52 PM
How to export playlists? Exporting comp tracks? Hugelittle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-16-2011 08:16 AM
Importing multiple tracks to 1 audio track for playlists DonaldM Tips & Tricks 6 08-01-2010 08:15 PM
