Opening a new a song, PT gets stuck
I am new on Pro Tools, so I don't know if this issue occurred also in previous versions. I have vers. 21.6.0.101 on Mac.
Often, when I open a new a song, PT gets stuck. So all I can do is quit PT and reopen it. Any workaround? Thanks
MUSICNET STUDIO Via Puini, 97 57128 Livorno ITALY |
Re: Opening a new a song, PT gets stuck
If OS is OK First thing try trashing your PT preferences https://www.sweetwater.com/sweetcare/articles/how-do-i-trash-my-pro-tools-preferences/ Then What if any 3 rd party plugins do you have installed , and have you made sure that they are compatible with PT 2021.6 and or are updated to run on PT? version . You can start by moving any third party plugins to the a separate folder and see if still happening if than then try adding them back to the PT preference folder on at a time to find on that may be causing an issue OR try uninstalling PT and reinstalling
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
I tried trashing preferences but the issue remains.
My guess is an old trial plugin or an out of date plugin causing that.
I know this is a time eating way but try putting ALL 3rd party plugins in the unused folder and keep adding 5-10 at a time until you done them all and at the same time look for old demos and old plugins that might need updating. PT will be doing weird things even if the offending plugin isnt in a session but since PT loads all plugins and VI it cause issues by just sitting idle in the plugin folders.
I see. I will try thank you
f
Gets stuck where? Sometimes PT takes what seems like forever restoring tracks even in a small session.
It's weird but at the moment I don't have this issue anymore...
I will let you know if it will occur again
If it happens again let us know exactly where it gets stuck.
Ok thank you so much
Be very careful with plugins. It only takes one bad plugin LOADED into memory to cause trouble with PT. The plugin does not need to be instantiated in a session, simply residing in memory is enough to cause chaos.
Every time when you update OS or PT you would also need to check if some of your plugins are updated on the vendor site. Of course it takes time, but that is the only way to keep your system stable. Not so critical if you only mix by yourself, but in front of paying clients it is embarassing if your system does not work properly. And if you do a live gig (recording artist or god forbit FOH mixing in front of audience) you cannot afford to have a bad plugin in your system.
PT 10 gets stuck opening song session | yorgo | Pro Tools 10 | 6 | 01-29-2015 09:02 PM |
Playhead stuck at song start. | YYR123 | Pro Tools 10 | 3 | 10-21-2013 06:35 PM |
Session getting stuck while opening | Micah777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-24-2010 04:39 PM |
Opening Help! ProTools 8.03-Get's stuck loading AutoTune 5 | WorshiperDj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 01-23-2010 05:24 PM |
OT- Worst song to have(and you have had) stuck in your head? | Captain_Pants | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 42 | 01-04-2003 05:45 PM |
