Old 08-09-2001, 08:58 PM
snoopy snoopy is offline
Default "Cannot allocate Disk Space"
I did a low level format of a drive, now when I try to record in a session I get this error.
It's a Seagate Cheetah 10k rpm SCSI drive in a hot swap bay. I have 4 of them and only one is giving me this problem.
WHen I record 30 or 1 tracks it gives the error, yet if I start the recording a few seconds into the session, it works fine. THe drive has 18 gigs of free space so I am not sure what I am doing wrong. Any advice is appreciated, I will post additional system info if needed. Thanks!
Colin Miller
Teaboy Audio Recall Sheets
http://teaboyaudio.com
Old 08-10-2001, 05:58 AM
DigiTechSupt's Avatar
Default Re: "Cannot allocate Disk Space"
-Open the Setups>Preferences>Operations window and try lowering the “Open Ended Record Allocation” to 10-20mins.
Brent
Avid Audio Tech Support
Support FAQ
Old 08-10-2001, 07:52 AM
adam_w1 adam_w1 is offline
I had a similar problem in Quickpunch recording drum/live sessions until the open ended disk allocation was reduced to a smaller number of minutes. It looks like the system looks ahead & multiplies time by track count for the disk space it figures it needs, and if it comes up short will refuse to record, or in some cases throws you out of record. In some situations the disk space indicator will actually toggle between values as you go in and out of record mode! [img]images/icons/rolleyes.gif[/img]
life is too short for bad mixes.
online mixing
mixing coach
Old 08-10-2001, 08:53 AM
BEfore I could test reducing the record allocation (though the shortest length would be at least 60 minutes fo me) the problem went away. Hoever beforehand I was unable to get ATTO to see the drive volume. I had to reinstall the drivers and then mount it. I think the drive may be going south. Thanks for the help guys!
Colin Miller
"could not allocate space on disk for recording" Jenk2k macOS 0 02-26-2012 08:40 PM
"unable to allocate disk space for recording" error guslov 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-01-2002 08:15 AM
"could not allocate disk space" opusone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-18-2002 08:52 AM
"Unable to allocate disk space" window AL DOGG 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-02-2001 08:58 PM
"Unable to allocate disk space" window AL DOGG 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-01-2001 11:32 PM
