Old 12-26-2023, 09:54 AM
ZorkNation ZorkNation is offline
Default 2023.12 problems with default paths and OneDrive
Because of the problems with OneDrive and files installed by PT with illegal characters (a separate thread), I changed OneDrive settings to not sync the Documents folder, so /Users/hedges/Documents is now an unsynced folder on disk.
In this case, starting Pro Tools still installed some files to /Users/hedges/OneDrive/Documents/Sketches and .../Track Presets. Nothing else. It installed all the rest of its files to "/Users/hedges/Documents/Pro Tools".
I changed PT Operation settings to use an unsynced folder outside documents for all files and cache, copied the available directories from Documents to the new folder, then deleted "/Users/hedges/OneDrive/Documents/Pro Tools" and "/Users/hedges/Documents/Pro Tools".
In this case, starting Pro Tools still created the following empty directories:
Code:
/Users/hedges/Documents/Pro Tools/Sketches
/Users/hedges/Documents/Pro Tools/Pro Tools Presets
/Users/hedges/Documents/Pro Tools/Pro Tools Presets/Track Data to Recall
/Users/hedges/Documents/Pro Tools/Track Presets
/Users/hedges/OneDrive/Documents/Pro Tools/Sketches
... and in the outside unsynced non-Documents folder, "Pro Tools Presets/Track Data to Recall" and "Track Presets" were created. The latter was populated with files under subdirectories. However, the "Sketches" folder was not created in the outside folder, and was not populated.
Something seems a bit wonky in the logic that creates and populates standard directories when Pro Tools starts up.
PT 2023.12, MacOS Sonoma 14.2, OneDrive 23.246.1127.0002 (Standalone).
Old 12-27-2023, 02:28 PM
paul_g's Avatar
paul_g paul_g is offline
Default Re: 2023.12 problems with default paths and OneDrive
Probably not good to use OneDrive with a PBA (Purpose Built Appliance). I try to dedicate my Mac soley for Pro Tools and not have anything that can cause overhead, confusion and otherwise issues.
Onedrive wreaks all kinds of havoc on my work windows laptop. I was forced to do a project in OneDrive so my team could collaborate. Even if they didn't touch the file, things got deleted, moved, changed etc.. One day I lost 4 hours of work on a file that was due to present to a very large client within hours of the meeting. Luckily I knew all the changes that had to be made and zipped through them.
Problem with OneDrive is, it's not a file and sync with versioning. MS set it up so the objects that live on Onedrive, LIVE on Onedrive, not your hard drive. What's worse is the the latency when working in these files not to mention, they are not versioned. If it's deleted, or changed, it's gone for good!
I wouldn't even think about having collaboration, sync, file-n-sync stuff on my PBA for Pro Tools. I'd remove that from your Pro Tools box and I bet all your problems will go away.
If I ever need to share something with someone else, I have a Synology NAS where I can just copy files (word, etc...) up too, then access from my windows laptops.
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Some bus paths could not be mapped to their previous output paths. Kbiastre Pro Tools 2019 4 02-02-2020 03:31 PM
Onedrive rant JuanPC General Discussion 18 07-13-2016 06:53 PM
Stereo HD Native Low Latency monitor paths are a no go with active surround paths? vieris Pro Tools 12 3 07-27-2015 06:07 PM
What are the default paths for storing AAX files? WilliamKalfelz AAX Plug-ins 4 07-22-2014 11:38 AM
Default-paths in Protools Bigpit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-09-2008 05:16 AM
