  #31
Old 01-23-2022, 05:19 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Sample accurate digilink interfaces in 2019?
Hi, welcome to the community.
Why not adding HD option card to your Symphony, then it would connect via DigiLink and be seen as Avid interface by PT
Janne
  #32
Old 01-23-2022, 05:55 PM
jerrybarnesbass jerrybarnesbass is offline
Yes I have that HD card in my Symphony MKII
but when I tried to do parallel hardware
compression on busses or as a hardware insert it doesn't automatically compensate in the same way as when I use a Avid compatible interface
  #33
Old 01-23-2022, 06:02 PM
JFreak's Avatar
You haven't read this?
https://apogeedigital.com/drivers/SI...ndum_FINAL.pdf
Janne
  #34
Old 01-23-2022, 06:20 PM
Thanks
I did not read that
Im not a technical dude
but I will have someone help me make sure im set up right
thank u !
  #35
Old 01-23-2022, 06:29 PM
JFreak's Avatar
No problem.
Janne
  #36
Old 11-09-2023, 09:41 AM
SaschaP SaschaP is offline
Bumping this old thread.
Does anyone know if the Focusrite Red Line 16 is sample accurate for hardware inserts when using it as a Thunderbolt interface? Is the issue just with digilink. Thanks!
  #37
Old 11-09-2023, 10:05 AM
Yes but now you are asking a non-HD non-HDX question on a thread in the HD/HDX forum and the answers are very different. If you ask this question in a better place I'll give you a full answer. I don't want to mess up this thread for other users. Edit: just saw you post the same question elsewhere so will answer there.
  #38
Old 11-09-2023, 10:55 AM
Thanks!
List of third-party Digilink interfaces? Matt Hepworth Pro Tools HDX & HD Native Systems (Mac) 14 11-19-2023 02:49 PM
Interfaces under Inputs say DigiLink N/A. What's going on? [solved] Focuret Pro Tools HDX & HD Native Systems (Mac) 0 03-17-2018 10:23 AM
Sample accurate recording derekvh Post - Surround - Video 2 02-03-2014 08:55 PM
AC3, is it Sample Accurate? minister Post - Surround - Video 13 03-13-2007 10:57 AM
Sample accurate midi? Dopamine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-09-2005 11:48 PM
