Old 04-06-2002, 08:59 AM
leon777 leon777 is offline
Default Help needed in choosing Trak2 or AD8000SE with outboard mic pre\'s...
I was about to purchase a Trak2 for my Pro Tools Mix+ system but just came across a demo deal with full warranty that sounds awfully good. It's The AD-8000SE, One AmBUS Digi8 card, 8 channel SE DA and the IFC-8DA db25 to XLR breakout cable all for about 5k.
This deal sounds very appealing and is only about $1500 more the the trak2 will cost me
with the digi8+ card and will give me 8 converters. The only problem is that I will have to use the control 24 mic pre's or invest in some other outboard pre's.
I'm just looking for some advise as to whether this sounds like a deal worth pursuing of if there may be a better road to take. I have no digi interfaces or converters at this time and I'm really trying to make the right choice with no regrets as far as converters and mic pre's go.
Thanks...Leon
Old 04-06-2002, 11:22 AM
MattiMattMatt MattiMattMatt is offline
Default Re: Help needed in choosing Trak2 or AD8000SE with outboard mic pre\'s...
I haven't thought about the numbers at all, but, FWIW, the mic pres on the Trak II are excellent. Plus, if you're considering PT HD, you can forget about using the 8000 as a direct interface.
-M.M.M.
Old 04-06-2002, 02:49 PM
No Control 24 yet or anything for that matter aside from PT Mix+. Just awaiting the right decision. I'm swaying towards the AD8000SE and correct me if I am wrong but is the price I mentioned too good to be true? That's the AD-8000SE, One AmBUS Digi8 card, 8 channel SE DA and the IFC-8DA db25 to XLR breakout cable all for about 5k.
Old 04-07-2002, 12:42 AM
ejsongs ejsongs is offline
I love the trak2
If you already have the control 24 you might be better off with the ad 8000. The reason I say this is that the control 24 has no ins to PT and you need a converter to go between the two. I don't know how the mic pre are on the control 24 but I can vouch for the trak2 ... they are awesome.
I guess what I'm saying is that it makes more sense to me to have an 8in 8 out box with the control 24 than a 2in 8out box. alot depends on how you will use the control 24. If it will be just a contoller with no analog signal going through then get the track 2. If you will route stuff like keys, drums etc then get the ad 8000.
ej
Lining outboard pre's through the Digirack pre's falsemetal666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-16-2006 04:53 PM
Using 002R Mic Pre's with an outboard compressor.. xeetstreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 08-27-2005 12:36 PM
OUTBOARD Mic Pre's.... minor2nd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-14-2004 02:33 AM
Outboard Pre's and Converters for 002... Booyah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-15-2003 07:42 PM
help needed in choosing trak2 or mini-me or what with PT Mix leon777 Pro Tools TDM Systems (Mac) 9 03-24-2002 12:41 AM
