Old 01-11-2008, 08:03 AM
simplemix simplemix is offline
Default Help! buffer size
OK, long time mix user. very stable. Legacy system but runs fine. Really wanted to start using some of the new plugs and can't on legacy systems. bought an 002r for this reason. Using a dual 1GHz G4 with 1.5 GB SDRAM. Pro tools boots up fine, using strike plug, only 1 plug, start to record in less than 3 measures, pro tools stops and reports that I need to increase the buffer size. I have gone through all the buffer sizes and it happens every time. I know there must be something missing here, have searched user conference but really need help. What can I do to record with plugs?
Thanks again
002r, G4, dual 1GHz 1.5 GB SDRAM, OS 10.4 pro tools 7.1
Old 01-11-2008, 09:24 AM
Phil Ogden Phil Ogden is offline
Default Re: Help! buffer size
What troubleshooting steps have you done so far?
What is your situation regarding a separate audio drive?
http://www.myspace.com/philogg
Increase Buffer Size Error (Buffer at MAX) ??? PoPimp3069 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 03-29-2010 02:24 PM
6086, buffer underflow, hw buffer size and other errors on i7 rhythmtechnologies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 05-30-2009 08:36 AM
Increase Buffer size/Decrease Buffer size? kerick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-28-2006 12:00 AM
Hardware buffer size in relation to DAE buffer sricabla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-04-2006 10:30 AM
Increase buffer size...decrease buffer size.... Bodhisan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-08-2005 07:24 PM
