Old 10-03-2007, 06:41 PM
simplemix simplemix is offline
Default printing mix on 5.1
I have been reading and trying to understand printing a mix instead of bounce to disk. How is this done on 5.1? I am using 28 tracks and like to print a stereo mix. Any help would be much appreciated.
Thanks again
Mix plus, 2 888/24s, pro tools 5.1, g4, OS 9
Old 10-03-2007, 06:57 PM
jimlongo's Avatar
jimlongo jimlongo is offline
Default Re: printing mix on 5.1
Assuming you have more voices.
Create a buss to record through. REC Buss
Create an audio track that you will record to. REC TRK
Set the output of your master to REC Buss.
Set the input of the REC TRK to the REC Buss. Put it into record and go.
Either monitor the REc TRK or mute it and continue to monitor through your master output. Either is okay but obviously not both.
noise | jimlongo
Old 10-04-2007, 07:00 PM
Thanks Jim, I think I understand. I tried it but I need to know how do you creat a Buss to record through? Is this the same as an audio track?
Thanks again
Pat
Old 10-04-2007, 09:25 PM
jimlongo's Avatar
Create another buss in your I/O setup. A stereo buss. Call it something like REC BUSS.
Then set your master to output to this buss.
Also set the input to your audio track that is recording your mix to this buss.
noise | jimlongo
Some tracks not printing...WTF!?! googs Post - Surround - Video 2 06-15-2011 09:46 AM
Printing Performances Cloud_9 Virtual Instruments 1 06-02-2010 02:18 PM
OT - Printing CD's soundsurfr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 29 04-23-2004 06:15 AM
Sound Printing SpyAJ15 General Discussion 5 03-22-2004 05:29 PM
Printing fx Pietari Koskinen Pro Tools TDM Systems (Mac) 1 09-15-2002 04:01 AM
