A couple of questions
Just bought a MBox 2 Pro today and I just ran across this piece of info about Firewire drives:
Pro Tools LE Systems (with Pro Tools LE 6.9.2 or higher) with the following exception: FireWire 800 drives are not supported for record and playback with Mbox 2 Pro systems about 5 lines later: Hard drives using the Oxford 912 chipset interface have USB 2.0, FW400 and FW800 ports on them. Only the use of the FW800 or FW400 interface is supported on these drives with Pro Tools. These are the audio drives I'm using so am I to ascertain that I have to use the Firewire 400 ports from my audio drives? Also: I am running the MBox off the power supply, not the bus. Should I leave it on all the time (which is my natural inclination)? thanx in advance
MacBook Pro DuoCore 17" 2.16Ghz • OSX 10.4.9 •*2Gb RAM • MBox 2 Pro • ProTools 7.3.1cs3 • FW 800 w/ Express Card |
Re: A couple of questions
Mac Pro 3.7 Quad Core Intel Mac OS X 10.13.2 PT Ultimate HDX 2019.10 64GB RAM HDX I/O 16x16 Analog HDX I/O 8x8x8 |
Thanks. It will be easy enough to find out.
What about the power question? Should I leave the MBox on all the time? peace
Why would you want to leave it on all the time? What benefit?
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
filosofem
Aaron Mulqueen - 001 HD Native |
Park - the hardest thing on electronic equipment is usually powering up and shutting down. Pretty well known with computers at least.
I have a good battery UPS system in place so I'm not worried about that. I think I'll leave it on. peace
Couple Questions | Skeeter Joplin | Tips & Tricks | 3 | 03-01-2010 03:05 AM |
Couple of help questions | Brazen15 | Pro Tools M-Powered (Win) | 5 | 10-23-2007 12:54 PM |
Couple questions. | Don Geppert | ICON & C|24 | 5 | 10-05-2006 03:11 PM |
A couple questions | G_Bender | Tips & Tricks | 5 | 10-04-2005 08:15 AM |
6.4 to 6.7. A couple questions | dodo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-10-2005 01:38 PM |
