Old 12-30-2006, 06:12 PM
simplemix simplemix is offline
Default mix core, 2 farms, can\'t hook up 2 a/d converters
I have had a mix core system for 5+ years no problems. Only used 1 882/20 interface. Bought another one and hooked it up to the farm card. PT does not see it. Have tried hooking up the new one directly to the mix farm card, no problems. System is mix farm, 2 extra farms. G4 5 slot.
New to DUC, any help much appreciated
Old 12-30-2006, 06:54 PM
Default Re: mix core, 2 farms, can\'t hook up 2 a/d convert
You could hook up both interfaces to your Core card if you had a "Y" cable. I think I have a "Y" cable that I can sell you. Email me through my profile.
Old 12-31-2006, 09:38 AM
milesofwire milesofwire is offline
You can do one of two things, Trash all your digi/protools prefs. and select your interfaces when opening pro tools..
Or you can select Playback Engine in pro tools, you should be able to select it from there..
Old 12-31-2006, 02:37 PM
Happy, Happy, Happy! Changed the mix engine and it shows up in the inputs and outputs!
Thanks so much for the advice
Peace
Pat
Old 12-31-2006, 05:03 PM
RobMacki RobMacki is offline
Keep in mind that connecting two interfaces to two separate cards will eat up more dsp than using the 'Y' cable as Jonathan suggested.
Old 01-01-2007, 11:11 AM
Jeff Ulmer Jeff Ulmer is offline
Yes, and there were issues with running the interfaces off two cards instead of one, which is why I got a Y for my rig.
Recording artist/Engineer/Producer
Waves beta tester
D24 with DSP Farms -vs- Mix Core with DSP Farms Table Syrup Records Digidesign Hardware & Software 1 12-23-2007 02:35 PM
OT: D24 core and farms-still supported? Ken P Pro Tools TDM Systems (Mac) 3 09-11-2006 01:52 PM
new G4 DP macs incompatible with mix core and mix farms ! dirosa Pro Tools TDM Systems (Mac) 6 10-18-2002 09:01 AM
PT24 core w/2 farms...Is the Y better than all card outs? qr2r General Discussion 8 08-21-2002 07:34 AM
Digitest does not see Core & Farms but Pro tools does? Mount Royal Pro Tools TDM Systems (Mac) 2 03-25-2002 10:06 AM
