Old 11-29-2006, 07:28 PM
1511 1511 is offline
Default File Conversion
Hello,
Someone sent me audio files to work with (WAV). I couldn't import, because PT says,"File not useable by PT". The only thing I could manage was convert these files to mp4 in iTunes, then import them into my session. Then, I discovered the files were 16 bit /48k instead of 24 bit/48k and played back at 1/2 speed. I tried "Save Copy IN" at the appropriate sample and bit rate, but there was no change.
Does anyone know how I might be able to get these files converted?
Thanks,
Chas
PT 7.2, HD 3 Acccel, G5 2.5 DP, 8 gigs of ram
Old 11-29-2006, 07:41 PM
Default Re: File Conversion
QuickTime Pro? SoundConverter? iTunes (set to WAV encoder)? These are the first three that come to mind.
Old 11-29-2006, 08:42 PM
Thanks, Chief T., I'll look deeper into the iTunes option.
Old 11-29-2006, 08:44 PM
I'd guess they're IEEE 32 bit floating point WAV files -- you'll need to convert them to PCM WAV files.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 11-30-2006, 06:10 AM
Rail,
You are correct. The files are 32 bit 96k. Would you tell me how to convert them to PCM? I used iTunes to convert to 16/48k, but they're still play at about half speed.
Thanks,
Chas
Old 11-30-2006, 07:23 AM
Looking at Barbabatch and Peak. Both do batch conversions, but that seems to be all BBB does?
Any preferences?
Thanks
Old 11-30-2006, 07:33 AM
soundguydave soundguydave is offline
check out Max
Dave Kaduk
Particle Audio
Old 11-30-2006, 12:36 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
BarbaBatch is well worth the price. We've got 4-licenses and use it on a daily basis. Peak's batch setup is much more difficult to deal with.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 12-02-2006, 12:05 PM
abre abre is offline
1511. I believe the PTMP has some of your TDM features. If so try this: File> Import> Audio From Quicktime Movie. In the dialog box select All Files. Then you can import the 32 bit file. I learnt this by importing 32 bit Floating Point from Sonar PE5.
ptf File conversion jamesimm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-03-2012 11:59 AM
DVD Conversion (Vob File) for PT deek Pro Tools M-Powered (Mac) 4 12-02-2009 11:38 AM
SD2 file conversion Ian Wallace 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-29-2006 03:28 PM
pc to mac file conversion??? gregory dean 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-18-2002 04:55 PM
Need File Conversion Help? SteveGarman General Discussion 2 03-27-2001 09:53 AM
