Old 02-08-2015, 02:08 PM
tooold's Avatar
tooold tooold is offline
Default I didn't have "Automatically Create New Playlist in Loop Recording" checked...
...and now I need to comp vocals. I deleted prefs and missed that one setting everything back up.
Is the best way to create (or duplicate, not many plugs yet) the number of new tracks I need, then manually drag the clips from the clip list to the new tracks? Is there any faster/simpler/bulk way to do this? Any way to make clips from the clip list go to their original bar/beat reference position?
Feeling the pain of a lack of a brain...
Thanks,
Myles
System 1: 2023 Mac Studio 64Gb RAM, OS 13.6, PT Native 2023.12, Metric Halo ULN-8, LIO
System 2: 2021 M1 Mini 16Gb, OS 13.6, Native 2023.9, MH ULN-8 4d
http://www.mylescochran.com
Old 02-09-2015, 02:41 AM
GregV GregV is offline
Default Re: I didn't have "Automatically Create New Playlist in Loop Recording" checked...
Don't be too hard on yourself... Playlists mess me up sometimes too if you don't select your parameters in advance!
It shouldn't be too hard to fix though. Since all of your takes will have the same start point, just select them all in the list and drag them to their start point together.
I hope that helps...
Old 02-09-2015, 07:35 AM
joachim's Avatar
joachim joachim is offline
Maybe in SPOT mode, dragging all "sub-clip"s of one loop recording (not the whole file audio) at once to new tracks and choose "Original Time Stamp".
At least they all will be "batch-spotted" to the original position.
Maybe not all sub-clips, but the ones prior to the last sub-clip.
Must be repeated for each loop recording, though.
Works for me.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 02-09-2015, 08:25 AM
tooold's Avatar
Thanks for the help! You were right, as they were loops, they all went to the same spot, no big deal, just took a while and it's a little clumsy. I had forgotten how useful those playlists are...
Create New Playlist "Command+\" on Foreigner Keyboard? Spidouz Pro Tools 9 23 09-02-2020 01:30 PM
Error: "Pro Tools cannot be put online while in loop play or loop record mode." msg6794 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-12-2016 06:09 AM
Wrong "auto-rating" of clips during loop recording joachim Pro Tools 11 5 02-10-2015 11:58 PM
Pro Tools + EX Drummer 2 - "n/a because Possible Feedback Loop detected" no recording gundry AAX Plug-ins 0 12-21-2014 02:49 PM
"compensate for i/o delays" not staying checked zakco Pro Tools TDM Systems (Mac) 7 11-11-2011 03:15 PM
