Old 01-20-2015, 05:29 AM
Jellestokhof Jellestokhof is offline
Default Delay compensation Problem when tracking
Hi guys,
I'm running into a bit of a problem with PT11's delay compensation.Here's the situation. I do a lot of bass recordings at home. These recorded parts need to be sent to other people. I like to send them one clean track without any eq/compression and one with eq/comp. I thought I could record and print it at the same time using two audio tracks.
One that gets input from my DI. That's where I put the plugins and a bus send. The other one gets the bus input and no plugins. The bus is post fader so the plugins are "printed" to the new track. Somehow, I get about 1150 samples of delay on the printed track. Am I missing something? I've read about some problems with the delay compensation but still not sure how to fix it
Here's a screenshot!
Anyone? Thanks!
Macbook pro (mid 2010), 2.4GHz, 8gb RAM, Osx 10.10.1
PT11
Apogee Duet2
Waves
Old 01-20-2015, 05:48 AM
studiosus studiosus is offline
Default Re: Delay compensation Problem when tracking
do you use the latest protools version and also the latest plugin versions aviable?
i had the same problem with an early pro tools 11 version and early aax plugins.
what happens if you route the output from "TRACK" to the bus 1 instead of using the send a?
Old 01-20-2015, 06:44 AM
Yes and yes :) Using PT11.3 and just bought the ssl bundle yesterday so I'm guessing thats up to date as well.
Tried your suggestion, same results actually. Even with all the plugins disabled I'm getting the same results..
EDIT: If I record on the TRACK channel and print it on the MIX channel, everything is spot on though..
PT11
Apogee Duet2
Waves
Old 01-20-2015, 08:21 AM
albee1952 albee1952 is online now
You could also just record the original track(and keep the plugins if it sounds better during tracking), then either process the audio with the AudioSuite versions of the same plugins, and export that. Or, solo the track and do a quick off-line bounce to disk
Old 01-20-2015, 08:25 AM
Well yes, there are obviously tons of workarounds but still.. It's weird that PT can't handle these two tracks without some delay.
PT11
Apogee Duet2
Waves
Old 01-20-2015, 12:46 PM
Did you check the box in IO setup for "automatically compensate after record pass"(or something like that)? Not sure it will help, but, why not try it and see...
Old 01-21-2015, 01:54 AM
I cant seem to find that option anywhere.. FYI, not using PT|HD but the "software" version without Avid hardware.
PT11
Apogee Duet2
Waves
Old 01-21-2015, 02:39 AM
GregV GregV is offline
I'll admit that I'm actually new to the Delay Compensation world. I only recently upgraded from PT8. That being said, I'm honestly not surprised by this problem... If you think of it from the mathematical perspective.
Delay Compensation, I believe, is a playback feature. It calculates how much time it takes for a plugin to do its processing and so adjusts playback accordingly.
However, to record with and without plugins at the same time gives the computer no opportunity to create a "frame of reference" for how much delaying it needs to do.
Therefore, your effected track will automatically have the delay that PT WOULD HAVE compensated for during playback.
But since you recorded it at the same time, now the delay has been built into the file.
Unfortunately, I think a workaround is the only option.
Again, I'm not sure if my information is 100% accurate. But you got the result that I would expect.
Old 01-21-2015, 03:21 AM
Well it sounds logical if it were not for the fact that if I set the output to a bus (which technically takes the place of my speakers) I still have the same problem.. So the output comes later than it should basically.
PT11
Apogee Duet2
Waves
Old 01-21-2015, 05:43 AM
There's definitely a miscommunication here... I'm not sure on which end though...
Your screenshot clearly shows that the audio was recorded late. At this point, there's nothing that delay compensation will do to fix it.
Delay compensation fixes tracks that are IN TIME with each other, but forced OUT OF TIME by plugin processing.
You have recorded two track that are out of time. So no matter what you do with bussing and signal routing now, it will always be out of time.
The easiest/fastest fix is just to slide the clips so that they start at the same time.
Sorry for the confusion
Problem with delay compensation juh macOS 10 04-15-2013 06:04 PM
Delay compensation when tracking Boe Larsen Pro Tools HDX & HD Native Systems (Mac) 10 10-21-2012 10:20 AM
Need help with Delay Compensation during tracking joeldadrummer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-19-2010 08:47 AM
My problem with Pro Tools HD 7.2 delay compensation jacko Pro Tools TDM Systems (Mac) 5 03-19-2007 12:10 PM
Tracking drums; delay compensation on or off? stormpro Pro Tools TDM Systems (Mac) 3 08-13-2006 10:20 AM
