adding internal ide drive to my g3 to record to
i have an mbox and am thinking of buying an ide drive to put inside my g3 and record to that. good idea? will work well? [img]images/icons/tongue.gif[/img]
Re: adding internal ide drive to my g3 to record to
What version of the G3 do you have? Depending on which version, it is easier/more difficult to add a second drive.
The initial B&W G3's aka rev 1 (300,350 & 400mhz) did not support the second drive option. It is still possible to add a second drive (I did) but it requires some additional materials. Rev 2 G3's (350, 400 & 450mhz) include the right cabling and mounting hardware for a 2nd IDE drive. Beige G3's use SCSI drives, and it's pretty easy to add another one of these internally or externally. To actually answer your question, yes it is a good idea to add a 2nd drive to your system to use for your audio projects, mostly because they tend to take up a large amount of space, and often the system drives included in G3 macs weren't very fast or big. Post your system specs, and we can help you find a good drive as well as install instructions to get you started. -Slim |
thanks. i'll check into the specs. and get back.
Cannot record on internal drive | MarcoM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-03-2008 10:04 PM |
Adding 2nd internal hard drive to G5.... | popps | Pro Tools TDM Systems (Mac) | 2 | 01-11-2007 04:03 PM |
record to internal drive | mulderden | Pro Tools M-Powered (Mac) | 2 | 12-23-2005 08:23 AM |
G5 - Adding an Internal ATA drive | 888 | General Discussion | 0 | 04-18-2005 11:24 AM |
Adding an IDE Internal Hard Drive for audio only | markus44uk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-11-2002 04:52 PM |
