Old 01-08-2024, 08:10 AM
Chevron Chevron is offline
Default Anyone else rocking a 2020 13" MacBook Pro M1?
I've been using this little MacBook for a month or so now, as a testing ground to see if a laptop was for me as a main studio machine before getting a 16" M3 Max MBP - and hot damn it is working surprisingly well on Sonoma - there are of course some known issues with Sonoma and PT, and Soundflow is not fully functional sadly.
However, I've been mixing medium-sized projects of up to 50 tracks with fairly heavy plugin use, and it has been working fine - activity monitor shows a fair bit of CPU and RAM overhead. It has been great to have the onboard camera (albeit poor res) and microphone for streaming sessions, meetings etc
This machine was planned only for home use, travel etc but I am pleasantly surprised how capable it is, and I thought to mention it here in case someone might find it useful.
I tested it with Rosetta 2 early last year, and whilst it worked smoothly I was getting frequent CPU overloads on similar sessions from this past month.
I hope that translates well to the imminently arriving M3 Max MBP!
Pro Tools Studio 2024.3| Eucon 2023.11 | Mac OS 14.3.1 | Soundflow | Streamdeck | 16" Apple MacBook Pro M3 Max 16 Core 64 GB RAM | 2020 MacBook Pro 13" M1 16 GB RAM | Hackintosh i9 9900KS 32 GB RAM
Old 01-08-2024, 08:20 AM
tope d's Avatar
tope d tope d is offline
Default Re: Anyone else rocking a 2020 13" MacBook Pro M1?
Originally Posted by Chevron View Post
I've been using this little MacBook for a month or so now, as a testing ground to see if a laptop was for me as a main studio machine before getting a 16" M3 Mac MBP - and hot damn it is working surprisingly well on Sonoma.
I've been mixing medium-sized projects of up to 50 tracks with fairly heavy plugin use, and it has been working fine. It is has been great to have the onboard camera (albeit poor res) and microphone for streaming sessions, meeting etc
I tested it with Rosetta 2 early last year, and whilst it worked smoothly I was getting frequent CPU overloads on largish sessions.
Thanks for sharing Chevron!
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 01-08-2024, 08:32 AM
Thank you, and I hope this bodes well for a 16 Core M3 Max MBP when Pro Tools fully supports Sonoma!
"Can't locate PT authorization" PT 2020.12 and iLok USB Key Ben Jenssen Pro Tools 7 05-11-2022 10:14 AM
Yellow "move" box for plugin is off 2020.11 kilroyrock Pro Tools 2020 3 12-10-2020 11:10 AM
Best current "Advanced Tutorial" for PT 2020 DBK Pro Tools 2020 0 07-28-2020 08:58 PM
I/O issues PT 2020.5 macbook Pro 2019 Rmarcopolo Getting Started 1 07-12-2020 08:41 PM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
