focusrite control 24 and 002
can a digi 002 rack and the focusrite control 24 be used with logic???
2012 mac pro PT 2018 Presonus Studio 192 |
Re: focusrite control 24 and 002
The Control 24 can be used outside of Pro Tools ONLY FOR IT'S PREAMPS AND MONITOR SECTION.
(To clarify, it is NOT an interface and so you would run the pre's line out into your interface.) You would have NO OTHER CONTROL via it's faders or other buttons, etc. As far as the 002 - I know nothing about the surface, and as far as the rack goes, I've used it as an interface with Sonar. You'd have to research Logic to see if it can support a Digidesign interface. Hope that helps. Good luck
Shorty: Table Syrup Records Mac Pro 5,1 3.33 GHz Hex, 32GB EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23" OSX Sierra Pro Tools HD 11.2.2 Waves IOS, IOX, STG2412 Extreme Server (x2) Logic Pro X, DSP Quattro, Final Cut Pro X Waves Mercury+SSL+AbbeyRoads Trident S65 with embedded US-2400 Live: 2012 Mac Mini, Dual SSD, i7 2.4, 16GB Win 10, OSX Sierra LV1, MRSG Hardware from above (same gear) Dual Dell P2418HT Touch Screens Waves Icon X (x2), M, with Screens Custom enclosure |
Focusrite Saffire Pro 40 and Command|8 Control Surface | EmperorMusic | Third Party Interfaces | 2 | 02-15-2014 11:22 AM |
Can you use the Focusrite 18i20 Preamp with protools 10 without the mix control? | Kollen.col | Third Party Interfaces | 6 | 11-27-2013 11:24 AM |
New Focusrite Saffire Mix Control 3.0 Available | cwsand | Windows | 2 | 06-30-2012 10:02 AM |
Anyone have experience with the Focusrite Control 2802? | Judicious | Pro Tools 9 | 4 | 10-30-2011 03:59 PM |
Digidesign/Focusrite Control 24 | Heru | Pro Tools 9 | 4 | 11-13-2010 06:24 AM |
