Installing from scratch on a new CPU.
Picking up a new G5 and installing PT TDM (HD3) from scratch.
Anyone know the specific updates required for this undertaking. i.e 6.0 to 6.4 to 6.7 to 6.9.3cs? After final PT 6.9.3 install, I plan to just copy my Plug-In folder. |
Re: Installing from scratch on a new CPU.
Which installer CD do you have? A new shipping version should have 6.9
Rail
Yes as Rail said, you'll most probably get 6.9 install CD, 6.9 is fine for the initial install then you'll need to upgrate to 6.9.2 for tiger immediately (note that 6.9 will not run on tiger, so don't try to boot pro tools untill you have upgraded 6.9 to 6.9.2!!) You can install 6.9.2 for tiger on any version from 6.4 onwards. Once 6.9.2 is installed you can then install 6.9.3cs2 and that should be it untill 7 Chris
Excellent, thx. 6.4/6.9.2/6.9.3cs2
My post was unclear. I'm moving my rig from a G4 to a G5. My last PT CDROM was 6.4. Cheers |
OK - no prob. 1. use apple setup assistant - it will move lots of stuff over for you via firewire. 2. Run PT installer and REMOVE PT from the new machine 3. Run PT installer and install 6.4 -- restart, but do not launch 4. run 6.9.2 updater 5. make sure plugins are updated 6. run PT 6.9.3cs2 updater 7. update PACE ilok drivers Restart frequently when promted. DO NOT launch PT until all updates are complete. Obviously, make sure you have latest versons of all plugins. This is how I did it from my G4 to my current G5.
--Jeremy |
If you Have DiskWarrior or TechTools Pro update to latest versions, previous versions don't work with 10.4. If you Have Granite Digital FW 400 drives bigger than 120GB, dounload the updater. JC |
Cool! Thank you for that.
Need help, installing from scratch | Drum3r | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-06-2011 06:52 PM |
After installing Crossgrade, how would I reinstall from scratch? | Doug Ring | Pro Tools 9 | 2 | 12-20-2010 10:53 AM |
Installing PT HD From Scratch! | James Lugo | Pro Tools TDM Systems (Mac) | 13 | 08-30-2009 10:07 AM |
Serato Scratch | jeffreym | Tips & Tricks | 1 | 05-18-2004 05:20 AM |
Hey about scratch again | craiz730 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-27-2003 11:43 AM |
