Old 05-29-2023, 07:04 PM
psycho_monkey psycho_monkey is offline
Default Fades overriding sync point when snapping to grid
PT Ultimate, 2023.3, Monterey 12.6.1 on a Mac Studio (M1 of course).
Anyone else noticed that if your sync point is not at the start of a region, if you've also got a fade in at the start of the region, when snapping to grid (Apple+0) the fade overrides the sync point and the region edge snaps to the grid (instead of the sync point).
That's harder to explain than to do...
I'm sure this is new behaviour in a recent PT update.
Can someone else check this for me, make sure it's not just me?
(apple+, moves the sync point to within the region. Apple+0 to snap to grid. Then add a fade at the head of the region and repeat. It SHOULD snap to the same sync point. But it doesn't!)
Old 05-30-2023, 06:20 AM
smurfyou smurfyou is offline
Default Re: Fades overriding sync point when snapping to grid
Has it not always done this? I never use the snap to grid command but every other snap function operates with the clip start or end points. Unless you use a snap sync point command. Right?
~Will
Old 05-30-2023, 06:36 AM
No - the whole point of moving the sync point is so you can eg snap a region with a leading edge to the grid and keep it in time. Eg a tambourine where the impact isn’t the start of the sample.
Try it - out the cursor in the middle of a region and hit Apple+, - you get a little triangle (beat detective also puts these in if you leave a trigger pad). Then if you quantise the region using BD or snap to grid, it uses this as the reference point.
But as soon as you put a fade on - it ignores it. Which doesn’t make logical sense to me!
(But if you don’t use this feature - you probably can’t confirm or deny the bug!).
Old 05-30-2023, 01:25 PM
nednednerb's Avatar
nednednerb nednednerb is offline
That makes logical sense to me. I think opening a support issue for this would be appropriate.
It should still sync to a sync point, regardless of a fade being present. The chosen sync point should govern the placement of the clip, not a fade, here or there, this long or that long, etc.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 05-30-2023, 02:58 PM
No I know very well what a sync point is I just never use this Quantize feature.
For what it's worth I just tested it and I see your same behavior in 2022.7. So not a new bug at least.
~Will
Snap Sync point to grid only one time? oortone Pro Tools 2020 5 05-06-2020 04:19 AM
Snapping to Grid RichrdC Pro Tools M-Powered (Win) 2 04-13-2009 07:02 PM
on snapping region ENDS/SYNC POINTS to grid (rather than STARTS) EricWillhelm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-29-2009 11:16 AM
Repeating Regions w/ sync point grid reference deanguidry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-28-2006 04:31 PM
Snapping To Grid? skyman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-24-2005 10:17 PM
