  #31
Old 05-30-2023, 10:30 PM
Warube Warube is offline
Default Re: The fastest way to start playback
Originally Posted by nednednerb View Post
I definitely think the same way...
When I press PLAY, I want that.
Have you tried a transport button on a MIDI/controller rather than keyboard spacebar?
I'm currently using the MC Controll (Artist Control) as a control surface. I've used the Command8 and various others in the past, but none of them made the playback faster. There was a glitch about once in 1000 times, so out of fear, I stick to using the Space button.
  #32
Old 05-30-2023, 10:36 PM
Originally Posted by smurfyou View Post
I think the same way.
Reaper plays instantly for me. And very stable. I'm much more comfortable with PT but I'd consider Reaper live. Actually I've used it as a multitrack recorder.
I've been using Pro Tools for over 20 years and it's fast for editing, so I prefer it. However, if it's a case of lost technology and we can't go back, it might be time to consider alternatives. Thank you for the information on Reaper. I will study that along with Ableton LIVE.
  #33
Old 06-05-2023, 08:17 AM
EmilILönneberga EmilILönneberga is offline
Disable the video engine. It won't give back the full PT 10 HD playback experience, but it's much better.
Didn't see if you've already tried that, so apologies if someone already mentioned it.
  #34
Old 06-06-2023, 01:45 AM
Thank you.
I'll disable the video engine and test it out tomorrow.
  #35
Old 06-06-2023, 08:19 AM
smurfyou smurfyou is offline
That only helps if you have a video track online. Otherwise it just hangs in the background eating 4GB of RAM
You can take the video track offline for the same response without killing the whole video engine. That's what I do when I'm editing VO or something non-sync and get frustrated by the sluggishness.
~Will
  #36
Old 06-07-2023, 04:39 AM
The video engine has been disabled from the start, and since I only handle audio, I never enable it. It can't be helped that it continues to consume 4GB of RAM in the background, can it?
I asked a specialist in Japan, who suggested that the playback engine's cache size would be the most relevant factor. I tried changing the size and testing it, but the lag remained the same.
  #37
Old 06-07-2023, 08:15 AM
Cache Size depends on the amount of installed memory.
If you’ve 64GB of RAM installed, try setting the cache size to 32 or maybe a little higher.
Since nothing seems to help, have you tried to disable plug-in by plug-in to see if any third party software is the culprit?
Edit: The playback engine shouldn’t consume any memory if disabled. That’s why I suggested it. Taking a video track offline will improve the performance but won’t entirely kill the video engine.
  #38
Old 06-07-2023, 03:46 PM
I'm currently using a Mac STUDIO with 32GB of memory. Since 4GB is already being used, I've set the playback engine's cache size to 20GB. The latest Pro Tools can't use third-party software yet, so I haven't installed anything.
  #39
Old 06-08-2023, 11:33 AM
Okay, how does PT act with just one audio track and without any plug-ins?
  #40
Old 06-09-2023, 07:50 AM
Try the latest PT release. 23.6 seems to be snappier when it comes to playback.
Start Follows Playback ??? specialkm Pro Tools TDM Systems (Mac) 1 10-09-2008 01:35 PM
set start/end during playback broken nikki-k Pro Tools TDM Systems (Mac) 2 06-12-2007 11:46 PM
Can I start Playback at Session Start Time? LSW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-19-2006 03:04 PM
Can't start playback mulletar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-02-2002 06:39 AM
Playback won't start.. mjames08 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-21-2001 09:00 PM
