Old 11-24-2003, 12:03 PM
Bluetide Bluetide is offline
Default Disk Utility ?
I'm about to erase an external FW drive (for the first time), and I'm slightly confused about what drive icon to choose. I only have 2 drives (my MAC internal drive, and an OWC FW external drive). When I open Disk Utility there are 4 drive icons. The first one says 60 GB IBM-, then directly under that to the right says Macintosh HD. The second one says 80 GB Oxford, then under that says OWC Mercury. This is the one I want to erase, but what icon do I choose? I would assume it's the last one that says OWC Mercury, but I want to make sure before I make a stupid mistake. Thanks for any help.
Old 11-24-2003, 12:10 PM
mersisblue mersisblue is offline
Default Re: Disk Utility ?
each drive has two icons I don't know why but if you try to select the wrong one ( excluding the internal hd ) you'll find it doesn't have that option just don't pick one og the top two
Old 11-24-2003, 12:43 PM
DesertDude DesertDude is offline
the top one is the whole drive, the one under it is your volume ( even if it is not partitioned) choose the one under for utilities control.
DesertDude
1.25 Alu/1.5 ram/10.3.4
PTLE 6.4-002R-Live-Reason
Old 11-24-2003, 12:46 PM
Thank you for the reply. Both icons for the FW drive give me the choice to ERASE them. I think I'm gonna go w/ the last one. Hope I'm right! Thanks again.
Old 11-24-2003, 02:51 PM
Slim Shady Slim Shady is offline
You can choose either the one that says "80GB Oxford" or whatever volume name is listed under it. As a previous poster stated, the program lists drives first by their manufacturer/size/connection, then lists volumes that have been created on that drive underneath it. If you were to format a drive into more than one partition, multiple volume names would show up 'underneath and to the right' of the name of the affected drive.
Old 11-24-2003, 07:00 PM
Hey guys,
Thanks for clearing this issue up for me. Much appreciated.
Cloning my disk with "Disk utility" good choise? petmar macOS 15 05-17-2011 12:46 AM
Apple disk utility repair disk permissions vga Pro Tools TDM Systems (Mac) 8 05-11-2010 11:10 AM
disk utility Tuur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-06-2006 09:34 AM
Disk Utility/CCC Stig Eliassen Pro Tools TDM Systems (Mac) 7 08-07-2006 04:35 PM
Which disk utility are you using?? RhodesB3 Pro Tools TDM Systems (Mac) 4 03-04-2006 07:36 AM
